IPC CONFIG ISSUE
HI ALL I HAVE A MALIBU LTZ 2013 WITH IPC (UDB - DRIVER INFO ENHANCED (SEGMENTED) AND DONOR IPC 2016 LT MALIBU WITH IPC ( UDD - DRIVER INFO ENHANCED (MULTI COLOR STANDARD GRAPHIC) I ALREADY CHANGED THE VIN & PIN KM SHOWING PROPER BUT I WANT TO CONFIGURE IT WITH LTZ SPECIFICATION LIKE TPM SENSORS ETC THE PROBLEM IS WHEN I TRY TO CONFIGURE IPC USING ORIGNAL LTZ 2013 VIN ITS GIVING ME COMPATIBLITY ERROR ANY ONE HAVE IDEA HOW TO SOLVE THIS THANKS IN ADVANCE BELOW IS THE VINS'
ORI CAR : KL1GM5D56DB020020
DONOR CAR : KL1GJ5DU3GB521161
THANKS
Solved by TunnerXP
  • Replies 8
  • Views 564
  • So, you are programming UDD with UBC config file, correct? Of course it will not work. For donor cluster use ONLY donor XMLfile. Build your own BuildRecord file with DPS to match the desired options.
  • Yes, your donor did not have TPMS from factory - so it is very likely everything TPMS related is disabled in this IPC. Need to reload with correct cals to show TPMS data on screen.
  • Arbe_gtc
    Arbe_gtc
    in insignia b uhs info3: DID00a1 <Parameter ParamDefaultValue="00"> <ParameterName>P_ACC_SETTING_MENU_PRESENT</ParameterName> <StartByte>14</StartByte> <StartBit>7
What XML file are you using for configuration?
I mean, part number
I mean, part number
ORI 2013 LTZ.rarDONOR 2016 LT.rar
WHEN USING DONOR XML AND BUILD ITS GOING WELL BUT NOT WORKING SOME OPTIONS IN IPC WHEN TRY ORI ITS GIVING ME ERROR NOT COMPLETING
Also, some features may be disabled by calibration files - your cluster must have appropriate BIN files to have TPMS info on the screen.
So, you are programming UDD with UBC config file, correct? YES CORRECT.. BUILDRECORD TXT FILE I ADDED THE RPO CODE FOR TPM BUT CANNOT SEE ANYTHING ABOUT TPMS IN XML FILE EVEN IF I PROGRAMM WITH REQUIRED BIN FILE MAYBE STILL NEEDED CONFIG BUT HERE IS THE PROBPLEM I CANT SEE REGARDING TPMS IN XML
Dose anyone know the location of "P_ACC_SETTING_MENU_PRESENT" in IPC ?
DID00a1
<StartBit>7</StartBit>
<BitLength>1</BitLength>
<ConfData useConfData="true" />
<ServiceSection IsServiceAccessAllowed="false">
<Interpretation Text="False" Value="00" />
<Interpretation Text="True" Value="01" />
</ServiceSection>
</Parameter>
del
M Ch bobdion Pavel zamich85 Mykola Goriun E-Ing-X20XEV regloops BLUE LION chicking Inam Ullah jjagel MoeMan Elviss Pereira ABOMAZEN remiga muraskinas stensin Hek exc11 codebuilder Galaxie
