2020 Acadia BCM Clone or VIN Change
Hi all, new to the forums. Need some guidance on a 2020 GMC Acadia with a bad BCM. Found numbers matching one and need to change the VIN on it. I've looked at some of the softwares on here but confused as to what I need exactly. Any help would be appreciated. Thanks
  • Views 285
While new BCM is still outside the vehicle, try to dump the eemprom from replacement module - to find the stored PIN number. It will be easier to program this module to vehicle.
Without knowing PIN of replacement module and your car PIN - you will not proceed with programming module to this car.
CLONE IT,, VVDI OR IO
SHPSHP Shifty Lorenzo Barrientos marksal DumitrescuGabriel LIUCHUAN Laila Ahmed Naser Cleberson Santos tobiasp Galaxie notovi alatka asd Lyubomir Krastanov nev3r star GM-Enthusiast Enterlan stensin paul mike
