HMI 2.5 Astra K running functions on the table
Hello everyone, I've been struggling with a problem for a while now and I don't know how to solve it. I have the IPC, BCM, ECU, HVAC, Silvrbox HMI2.5, and radio display all connected according to the diagrams, unless I've made a mistake somewhere. I can't access the vehicle function; I get a message that the car must be in motion. How do I trick this for this function to work? Best regards to everyone.
  • Views 644
  • Arbe_gtc
    Arbe_gtc
    I've already spoken to him privately about this. The vehicle options aren't appearing because he can't power on the BCM. A BCM with keyless calibrations (like his car) can't be set to Ignition ON by c
  • Enterlan
    Enterlan
    BCM_moj_Kluczyk.zip
    issue is BCM need to know car is with Park brake applied or gear selector in Park position - depend of calibrations for Manual or Automatic gearbox
  • Arbe_gtc
    Arbe_gtc
Do you know a way to test or cheat this?
First you need to know what calibrations you have loaded in BCM and them - either get EBCM and Parking brake button, or get TCM and force to be in Park position.
I have a manual gearbox, my BCM from Astra K W0LBF8ECXG8059575 loaded, unfortunately I don't have the modules you're writing about
Open schematics for BCM /parking brake. You will probably have to short one pin to ground - this will emulate EPB in "On" position.
I've already spoken to him privately about this. The vehicle options aren't appearing because he can't power on the BCM. A BCM with keyless calibrations (like his car) can't be set to Ignition ON by connecting pins 5 and 6 of the X3 BCM to +12V or using a non-keyless switch connected to BCM. The BCM won't power on, but if it were a non-keyless calibration, it would work fine.
If you want to emulate a keyless system, you need more than just a keyless module; you'll need antennas, a keyless ignition switch, a start/stop button, etc. I have a keyless system on my test bench, and it works with all the components required for a keyless system. I can turn the ignition on using the start/stop button.
instead, you can change your bcm calibration 2 for one for non-keyless, and you can power on with a normal key
Thank you my friend Arbe_gtc was right, I managed to do all this thanks to his help.
Great result. Im planing to try this method as well. @Arbe_gtc do you happen to have bcm calibration file for non keyless system? I would like to make bench system simple as possible.
This is my bcm Astra k 2016 year keyless system
BCM_K9_Astra_K_2016_W0LBF8ECXG8059575_STOCK.zip
Thank you but Im looking for non-keyless
BCM_moj_Kluczyk.zip
Good evening, I have the same thing only as an Insignia on the table. Everything works, only when I connect the USB stick for an update the message Bring vehicle into parking position comes. I connected the handbrake and the control light in the UHS is also on. Only the UHS doesn't bother me. UHS is programmed to automatic. Think the BCM is from a manual vehicle? But where is the mistake then?
to make any usb update, need the ECM connected on the HS-Can, why? i dont know,
  2. GM-Enthusiast
  3. Last_Captain
    +Last_Captain
    20
  4. uglyoldbastard
  5. pupu14
    +pupu14
Adelin Camelot aaronprg Arbe_gtc Pasha Mikluha_Maklay pupu14 Opelfan syciu regloops Daniil_Ast jingwei chicking zamich85 Alpha Robi_X Yuliyan2133 Enterlan digital notovi
