Astra k 1.4 UHS Insignia B oil temperature
Hi Has anyone managed to enable the oil temperature reading on this small black screen so that it shows the real values in a 2016 Astra K 1.4 turbo 150 hp?
Solved by zamich85
  • Views 509
I have been unable to do it. I know somone that done it but using the data from transmission oil temp sensor.
Could you tell me how to do this? I'm considering this modification.
Is that a non-HMI radio by chance?
I don’t know how to do it I’m afraid. Person who did it, I’ve found it on Russian website, can’t remember what it’s calls unfortunately
Ok, I saw that someone tried to install sensors but I don't know how it ended, I know that someone on a Polish forum boasts about doing it but I don't know how
There's no need to install additional sensors. Oil temperature is calculated by the engine control unit and transmitted to the gauges. I did this mod in a 1.4t Astra K, and it works.
Could you please describe how to do this? Does it require ECU programming because I have a map already made?
Do you mind sharing how? I have currently got an ESP32 reading the calculated temp from the ECM and replaying it the the cluster, it works on the bench but it's not pretty.
Need to test on the car but if it can just be coded even better - from my research it seems it's just masked by the BCM as the IPC get's the info?
I can check it out at my place if you tell me exactly what to do. I have my BCM files, so I can send them to you.
  • 4 months later...
Good evening, is there now a solution to retrofit the oil temperature in the Insignia UHS?
No
For which engine?? If it's petrol, I have a solution.
It'll be good to know. I've fitted a UHS to 1.2 turbo engine on Astra K and the oil temp gauge is already working and I understand there isn't even a sensor for oil temp, so it's all in ECU. I assume that there are certain bytes used to activate it. My astra k is 1.6 turbo with e80 ecu.
  5. Last_Captain
    +Last_Captain
    11
Enterlan Opelinsignia1985 zamich85 Opelfan tobiasp Mikluha_Maklay exc11 pupu14 Garik67 hassan77h Adelin tungnv93pt alatka asd Troll Deryck Elviss Pereira Thamer Mo Robi_X syciu notovi apetrushenko
