Cadillac escalade 2015 cruise control not working
hi all as title says i have Cadillac escalade 2015 this car cruise control not working and there is no any dtc in car, and when i check data display cruise control switches working properly, i checked disabled history data its saying ( distance sensing cruise control communication malfunction ) in ECM i dont know what is the problem if any member faced the same problem before or direct me to the right direction it will be very appreciated here is the car VIN 1GYS47KJ5FR659704 thanks alot..
  • Views 387
  • GM-Enthusiast
    GM-Enthusiast
    Escalade is easy to align, no need to remove bumper, you need level bar, digtal angle meter or phone angle application The digital angle gauge must have an accuracy of ±0.5 degrees (9 mm/m). The verti
  • GM-Enthusiast
    GM-Enthusiast
solved thanks all
could have mentioned solution, that will help others too, Thanks
if no dtc,, cruise control module misalignment,, its says on data (yes) means error alignment on, angle, up, down, left and right,, need to align,
As GM-Enthusiast said exactly that was the problem in data i see there is misalignment but problem is that now how to proper align it? i cant see anything on plate for alignment but i am searching for this if i found a way i will definitely share this too ..
The vertical position of forward range radar module is 90 degrees (±3 degrees).
Cleberson Santos TunnerXP dt_precision Opelinsignia1985 Kennyfoberje Galaxie crakavelli BLKATSG GM-Enthusiast pupu14 Last_Captain Emmanuel Koomson marcel_hack_guy ameeraltihan blocked Hek
