Insignia A/ NG Saab 9-5 Airbag SDM (Vin and Immo re-learn)
First of all,, sorry for all the newbie questions coming up (i got my hands on GM DPS 3 hours ago) 😆
So.. Im replacing an Airbag-Ecu on my 2010 NG Saab 9-5 (same architecture as Insignia A), a used unit with wrong VIN
I got the Vin change file,with the help of Troy 🤩
Used Winrar, unpacked the file into DPSArch, programming went great..Vin is changed to the correct one.. No problem
So.. whats left is to re-learn BCM and Immobilizer, to write/hardcode new Vin..
Again.. got the necessary file from Troy.. and well.. from here on.. I would REALLY like a tutorial... as i somehow cannot import/use that file within GM DPS.. Just says " cannot unpack file, Error" 😬
Yes.. I am aware that i can use GM SPS to do the Immo-relearn, but i figured Troys file would do the trick?
  • Views 197
The issue arises because the DPS file you’re attempting to load is a Type4 file, which must be loaded using the DPS Type4 tab option.
This tutorial and files can be used to activate the DPS Type4 tab option.
digitaldiag BabyLonLand Renan Rex chicking veetdoc Danielb Sturla bart BRANDON BURDEAUX amazingjoey BLKATSG Carlos Zelidon Galaxie uglyoldbastard La Team Prep blocked tobiasp pupu14 Lyubomir Krastanov JBL_1989
