T93 tcm E90 ecm Global b bench
hi good day
i have T93 tcm E90 ecm Global b
in DPS work good w GATEWAY and BCM and godiag gt100
i trying to connect to Mpvi3 HPT
But it doesn't work Bench
Does anyone know how to connect the wires to make it work for me Mpvi3 HPT?
THANKS
  • Replies 14
  • Views 1.1k
  • GM-Enthusiast
    GM-Enthusiast
    add serial data gateway module ang follow data communication schematics, if by DPS ok, it must same as HPT, try add 120 ohms resistor on ECM high speed data
  • then tomorrow i will reply on after doing same setup on my bench
thanks for reply
i try connect serial data gateway module to obd2 and Mpvi3
i get msg Detect protocol failed
3 hours ago, A61bk said:
thanks for reply
WHERE IS YOUR ECM CONNECTION
SEE POWERTRAIN CAN AND POWERTRAIN CAN ENABLE
AND DOES YOUR MPVI CONNECT IN-VEHICLE,, DO IT FIRST BEFORE DO IT IN BENCH
IN-VEHICLE no problem
i ask about BENCH
I've tried several times, but it hasn't worked for me.
Where can I find POWERTRAIN CAN and POWERTRAIN CAN ENABLE in any CCM?
BCM, serial data gateway, ECM, and TCM all work on DPS and SPS2 without any problems.
Only on HPT, I GET Msg Detect protocol failed
If your scanner communicates and dps works too then your hptuner interface is banned
not banned
work good in Global A BENCH
great
thanks
I searched for problems and found this website:
BenchForce
No image preview
BenchForce OBD-II Pass Through Device w/ 120 Ohm CAN Term...
This BenchForce OBD-II Pass Through Device w/ 120 Ohm CAN Termination adapter attaches between your 16-pin OBD-II connector and your OBD-II Communication device providing 120 Ω CAN termination, aiding
BenchForce
No image preview
I received the device and tested it, but it's not working; I'm still getting the same message.
I'm still looking for a solution or searching for Pinouts about my MP3
what it reads and where it retrieves data from.
I await your help. Thank you
image.png both connected?
yes both
4 and 5
Ground
HI @Last_Captain
any update
saad_dubai mohammed Abe Llefi plcautoparts penguin4170 Adelin LIWA Byron Gutierrez tan tan Ramin ltuning Raminboushehri stroker Troll Deryck Mohammed Aljack Diko alaa_bastaki TunnerXP ErikRP Kpeezy
