Chevrolet cruze 2010 Immobilizer security code not accepted, no crank, no start
  • Replies 9
  • Views 808
The key may be faulty.
It has 3 key all inside the bcm file. No one work att the moment . The remote not work too.
This car usually loses the key code in the engine control unit (ECU). I disable the security system in the ECU, and it works.
Can you please explain how can i do it??
read eeprom 29F800BB
If the engine control unit number is [number] continental 76.1
, you must extract the file, disable the key code, and download the file again to complete the process.
I have a file for this car with the key code disabled if you want to buy it.
The ecu is mt80
ABOMAZEN John Stevens Amro Alamleh stensin veetdoc FASNASSRI chicking exc11 ruben casique daroopel warriorpluto Juan Carrillo jorgecostacv Last_Captain blocked A61bk Opelinsignia1985 pupu14 Galaxie Adam Krasuski
