calibration modification
hi everyone i'll skip the formalities.
i have 2 cals one has manual transfer case and the other has auto transfer case with e-fans activated
what i want is to mess with the 2 cals to use e-fans with manual TC
12662441.binauto TC with fans
2-12662440.bin manual TC no fan activation possible trust me i did every thing
anyone knows how to edit BIN files please help thank you all.
  • Replies 16
  • Views 1.2k
You could try using Hex editor Nero to compare both cali files to see if the codes are almost the same in both files, then swap some codes arround, correct the checksum and test it out.
The trial-and-error routine method is very time-consuming, but look on the bright side, you could get lucky. Sometimes I do 🙂.
Good luck.
Good luck.
Wont this method brick the module?
because this is an ECM cal and i have little experience in using hex editor.
I've modified Cali files in the past and never once bricked a module. The worst case scenario is that the modified file in the DPS archive will not fully program onto the module, and DPS will issue an error, or the module will not function properly with the modified Cali file. In such cases, using DPS to reprogram the module's original calibration files will restore the module's functionality.
Thank you for sharing your experience appreciate it 👍🏻
what make, model , year
440/gmc sierra 3500HD 6.0/ 2016
E92 or E78 POST BOTH VINS
2 minutes ago, GM-Enthusiast said:
E92, POST BOTH VINS
E78 both
6 minutes ago, wahab alnajdi said:
E78 both
E78 6.0 LC8 L96. can you send vin of E78 that have e-fan, and the vin of 3500
15 minutes ago, GM-Enthusiast said:
E78 6.0 LC8 L86. can you send vin of E78 that have e-fan, and the vin of 3500
its L96 what do you need the vins for???
we cannot compare and download calibration without vin,, its actual to program ecm,, i cant see any 78 trucks savana , siera, silverado with fans,, except e78 malibus
its up to you if you dont expose your vin,
You are correct but this car was custom programmed from the previous owner and the stock cals dont match with whats on the car it was costume programmed but i managed to retrieve the calibration number from a friend of mine he had many of them saved in one folder but unfortunately they aren’t organized by vin thats why im stuck with this issue
its different OS for sure, manual or auto TC is not issue,, if you can run the other ecm(with fan ) on your engine, no need more calibration,, clone it complete, delete dtcs, disable vats,,
Even after deleting the dtc its also stored in Abs module the ecm is causing this also with a stability track light on the dash
because the OS must not be chnage, if you can send both file, by hpt, or io, i can try it.
Correction: if both OS are equal you can change the cals however you like and thats what i’ve done when one system cal is giving me the auto TC and the other is manual TC but no fan activity
M Ch Jasper ABOMAZEN Firestars Dog Duba nev3r Martin Mendez PixelTheKWolf blocked Robin Hood extodd bondarrenko Hussein Althamir OP stensin ChevyPL thxx Robi_X Aleksandr daroopel
