ECC HVAC 13581132 no vin
Hello dear community,
I have an ECC in my astra j 2011 which cannot be programmed via sps. Under dps read out I see that no part number and no vin is programmed. Have you ever seen something like this? I have a complete eeprom dump.
  • Views 600
damage eprom
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ is unprogrammed module, hardware mismatch
See at CB and CC
That appears to be a damaged EPROM or corrupted firmware. You could try dumping the EPROM chip bin file from a working ECC, then program that ECC EPROM chip.
Hey,
I looked up the hardware number 13581132 for all possible software parts in offline TIS database for you.
The files TIS gave me are in the zip file, including utility file.
You can give it a try and build your DPS file with
0 Utility file
1 OS
2 Calibration 1
3 Calibration 2
For the Calibration 1 + 2 there are several files, it's up to you for try and error. The files are matching to the os, so nothing can be damaged.
Let us know, what's the outcome of your experiment...
Greetings and good luck,
Tobias
13581132 All Files.zip
MaxGood Adelin ARZZRIF chicking E-Ing-X20XEV LIUCHUAN Enterlan BADIS aleks nik aaronprg exc11 Galaxie Flash pvtILLY GM-Enthusiast pupu14 BLKATSG marcel_hack_guy SHARAWI Opelinsignia1985
