Corvette C7 dies after 4 seconds starting
Hello everyone ,
As the title shows , I'm working on 2019 Floaded C7 ZR1 , got new bcm , keyless entry and anti theft deterent , programmed via sps and did immo learning
the car starts then dies m anti theft is activated , all controls have the same vin except the cluster , while flashing bcm i choosed reprogrammong instead of replace , and stopped at bpp relearn
where to go from here , I have DPS m access to sps
  • Views 443
  • GM-Enthusiast
    GM-Enthusiast
    Repeat Immo Learn, Choose BCM Immo Learn with Existing Keys,, Some Car Need two Key to complete immo learn, (Camaro/Corvette Only) after immo setup complete,, follow on screen intruction and proceed t
  • GM-Enthusiast
    GM-Enthusiast
20 hours ago, Aljak said:
Hello everyone ,
Repeat Immo Learn, Choose BCM Immo Learn with Existing Keys,, Some Car Need two Key to complete immo learn, (Camaro/Corvette Only) after immo setup complete,, follow on screen intruction and proceed to BCM setup.
ok , so it's nothe used IPC ?
everything other than that is matched
IPC does not care on starting, if you want to match to vehicle,, Troy have the files you need,,
IPC VIN/PIN change file
Odometer Vin Change File(on BCM DATA)
Rickardo tobiasp Galaxie Aljak JBL_1989 Julio Balarezo BLKATSG aleks nik Emmanuel Koomson grand Lutfulloh Latifxanov Tomasz Grzanka Last_Captain Thomas Crosbie pupu14 Opelinsignia1985 MARKAR YEDOYAN star GM-Enthusiast crakavelli
