K157 Videomodul
Hello, have someone an idea who i can change the VIN from a Videomodul K157.
When i load the Software (DPS) on it it comes a Error Message after abaout 9 minutes.
  • Replies 18
  • Views 912
    So you try to retrofit 360vision to Astra, not impossible, but will be hard work. You should start with that. To change VIN as I say is simple, but your programming approach is wrong.
share your DPS log, so we can see what is wrong
hello i need some calibration file to gmc tahoo 2008 could you help me
here the Log File. I hope you can see something
ProgramLog.Txt
ProgramLog.Txt
By look file isn’t correct. As well to change vin is not need full flash. Share your car VIN and camera p/n to see what can be done.
Ok what Camera p/n you mean?
The Vin for this modul is W0VBE8EH0J8017204
yes, need camera p/n and provided vin doesn't have K157 module....
Do a GOOGLE search of vehicles that use K157 VIDEO PROCESSING MODULE.
RESULT: Used in a wide range of GM VEHICLES including those of the 2019-2023 model years.
BUICK, CADILLAC, CHEVROLET and GMC.
I believe for the USA market, working in conjunction with other compatible modules.
Yes, the VIN isn't for the module. But I'd like to try retrofitting the 360° camera.
What P/n from which camera ? Front Rear side?
Or the Camera in the Middle (Near Mirror)
@ Emmanel You mean this Number 84784629
It is for digital Camera an it is better. But i don`t know that did works on an Insignia or an Astra. Have someone here a Wiring Plan from this Modul ?
I stand to be corrected but the k157 may not work on an Astra. It has to be programmed to work.
Get a universal rear or front view camera. Lots of them on the internet especially comes with alarm systems.
That part number is for 2020 Silverado 1500 and Sierra 1500 models. (ONLY)
It works with Park Assistance Module, BCM etc.
Ah ok it need the bcm and the Park Module.
Ah ok and who can i load and change the vin. Where is the pN that you need
Open manual for DPS (located in program folder) and search on how to get controller info. Then post the results...
I Know the Controller info but i don't know what the p/n from the camera is. Or see i that when i looked on the Controller info?
@ Lyubomir Did you mean the Part number ? This is 39039427
Robi_X Enterlan marcel_hack_guy whopa redmouf apetrushenko OP domdel Flash Layne Bumgarner ΓΡΗΓΟΡΗΣ γκοτσικασ joey mmk tobiasp QUSAY OSMAN aleks nik Galaxie artur minasyan Emmanuel Koomson Arbe_gtc Yuliyan2133
