2017 equinox
Solved by GM-Enthusiast
  • Replies 9
  • Views 2.3k
Have you tried updating/reloading calibration files through SPS for this module? It should fix it. If not - module is corrupt and needs to be replaced.
Which one 👇👇
DTC B101E 00: Electronic Control Unit Software
DTC B101E 31: Electronic Control Unit Software Internal Checksum Error
DTC B101E 32: Electronic Control Unit Software General Memory Malfunction
DTC B101E 41: Electronic Control Unit Software Not Programmed
DTC B101E 42: Electronic Control Unit Software Calibration Not Programmed
DTC B101E 43: Electronic Control Unit Software EEPROM Incorrect Programming
DTC B101E 44: Electronic Control Unit Software Security Access Not Activated
DTC B101E 45: Electronic Control Unit Software Variant Not Programmed
DTC B101E 46: Electronic Control Unit Software Configuration Not Programmed
DTC B101E 47: Electronic Control Unit Software VIN Not Programmed
DTC B101E 48: Electronic Control Unit Software Security Code Not Programmed
DTC B101E 4A: Electronic Control Unit Software Programming Checksum Error
DTC B101E 4B: Electronic Control Unit Software Calibration Not Learned
DTC B101E 4C: Electronic Control Unit Software DTC Memory Full
18 hours ago, GR Auto Repair said:
I have a problem with my car, code B101E. How can I solve it?
screenshot of symptoms byte?
he did not mentioned he is talking about which module, this code comes in many modules so he need to mention which module he is talking about, YES symptoms byte
If yourEPS is 2 bytes then you need this
https://www.cameraloops.ru/files/file/591-eps-vin-change-equinox-and-captiva-2-byte-seed-dps-archive/
One of the sensors that detect blind spots is located in the bumper; use one on each side on the inside.
dgjtools Evans Appiah ViCo2 Selase Nuapah Fire Phoenix Kaotic Thomas Crosbie AL RAED palihustla GR Auto Repair Mjnon Gamer Autobitas Galaxie Robi_X GM-Enthusiast thxx codebuilder
