2021 Silverado SDM programming
I've got a customer taking a 2021 Crew cab 6.2/10spd and swapping it into a 2021 Reg cab. Is it possible to change the cal files in the sdm so it has the same calibrations in the sdm of the crew cab as it does in the regular cab? Does that make sense?
  • Views 573
you need regular cab calibration or,,, add rear side impact sensor left and right, attach to body.
I should be able to get that from the regular cab vin. I was just making sure I can do it.
kevin cory Jaydog kari_v TunnerXP Emmanuel Koomson AL RAED Jose Nava penguin4170 JJance ProTek joeservo Adam Krasuski
