Chevrolet Aveo 1.4 MT80 Immo off
Hello, I have here a broken Ecu MT80, no power suply and cant read it. I have other one and need to make it run, Can someone help me?
dflash.bin pflashsave20250219_160831_209.bin
  • Replies 12
  • Views 1.1k
Usually, if an ECU is not responding to power, it may have component damage. The easiest route is to source an identical ECU from eBay or scrapyard.
Yes, I did it and why now I need immo off of the second hand one, the car is far away and can't adapt it on other way.
What’s the vehicle model name and year of make?
It's an Aveo 2009, 1.4 manual gearbox
Ohh now see that the model name was already in the topic title but hidden due to the banner, I’ll have to fix that.
Have you tried using GM Tech2win tis2000 to program the ECM. I could be wrong but I think 2009 modules uses Tech2win for programming.
Yeah, wrong info. 2009 is Global-A so not tis2web.
What programmer is MT80 read with? If you send the reading from the BCM eeprom, I can prepare the immo data.
The CPU is Tricore, the reading I uploaded here is from Vvdi prog, I made reading with Flex but epprom is larger, not real.
You need a BCM eeprom reading, as for the MT80 reading, include the Flex reading.
This cas is with immo box and immo data ia there, not in bcm...
Program ECM by SPS..
Set Key to Neutral by Tech2Win...
The car is far away from me, I got only ECU. Trying to help a friend....
ABOMAZEN amir_theee LIUCHUAN orlando bolskaya giosoftmx QUSAY OSMAN
