Astra K IOB Radio - Enabling the climate menu
Hello people,
I thought I'd drop a post on here to see if anyone here had an experience enabling the Climate menu on IOB radio, specifically for Astra K.
I understand that Insignia-B with IOB and CJ2 usually have the climate menu enabled, although when I was testing insignia-B calibration onto Astra K, the display was somehow changed upside down, I didn't get much luck with changing varies calibration so far. This is what the climate menu looks like after insignia-B case was programmed in.
I will probably have more time this weekend to investigate it further, for now I am wondering if anyone has attempted these climate menu.
  • Views 2.1k
  • Identifying which calibrations are signed and which are not is quite simple. If you open the calibration and see this:   It's signed. This happens on some units, not all. (Serial
Hello, i am test the same, Can you send me the File for test it on my Astra K?
I haven’t done a lot on it just yet. I do have files with identical RPOs from both Astra K + insignia (+CJ2) that I need to make a breakdown to identify the bytes for the climate menu.
I only know that insignia B have 7 speakers but it doesn’t affect software wise.
Hy,
I have on my Astra K 2018 IOU in the Car the Software for the Menü works on the Display. The HAVAC Module need another Software
The problem is, in the IOB/IOR radio types like this:
The calibrations are signed. Cant be Edited. Then, you cant find differences to enable or disable options
I have the Newer one  IOU (Harmann). I need files for the Havac Modul for this. The Radio Modul have the Radio have the Options aktivated.
Ah and the Wiring is another From Insignia and Astra K
That's interesting, so it is even harder to change the logo on IOB. Look like we have to find a way to get the custom calibration signed somehow..
It's signed.
This happens on some units, not all. (Serial Data Gateway, some engine control units like E88, R4 Radio (ior,iob), Harman Info3 Radio (ios iot iou)
And for the moment, it seems unlikely that such encryption can be broken.
You need to replace some calibration files without changing them and try to flash them. There was such a problem, but everything was solved by firmware
I’ve tried this, it isn’t easy though as the climate menu is in insignia B models, however I able to understand which calibration have climate menu but it was these calibrations that cause the display to be upside down.
Show me the calibration numbers you have?
Astra K IOB: UZ6, UC3, EU1, CJ2, UE1, U2Q
Software Module 3 39139421 Unknown
Software Module 4 39171660 Unknown
Software Module 5 39065923 Unknown
Software Module 6 39065926 Unknown
Software Module 7 39186150 Unknown
Software Module 8 39065933 Unknown
Software Module 9 39140854 Unknown
Software Module 10 39065930 Unknown
Software Module 11 39040387 Unknown
Software Module 12 39139424 Unknown
Software Module 13 39135003
Unknown
Insignia B IOB: U65, UC3, EU1, CJ2
Software Module 4 39162976 Unknown
Software Module 5 39121668 Unknown
Software Module 6 39065259 Unknown
Software Module 7 39115822 Unknown
Software Module 8 39019537 Unknown
Software Module 9 39115767 Unknown
Software Module 10 39065262 Unknown
Software Module 11 39052792 Unknown
Software Module 13 39121671 Unknown
Hallo,
any Progress here? Does anyone has more infos about the Signiture of the Calibrations files? Or what file does what?
Adelin MaxGood Roman Roman alatka asd ViCo2 Lyubomir Krastanov John Stevens blocked syciu exc11 zamich85 Enterlan PixelTheKWolf GMcars marcel_hack_guy tejiera Arcani amazingjoey Dukie BLKATSG
