steering column module
hello,
how can Cancel or delete  steering column module for gmc yukon 2015
  • Views 435
  • I have a problem with the steering column module lock. I don't want to change it. I want to delete it or cancel it from the car by modifying the BCM file. I want the car to work without the steering c
Unclear question. Can you try to explain exactly what you try to achive?
I have a problem with the steering column module lock. I don't want to change it. I want to delete it or cancel it from the car by modifying the BCM file. I want the car to work without the steering column module.
You can try comparing a 2015 Corvette USA spec BCM, to an 2015 Corvette export spec BCM.  That might get you the correct hex locations for your truck.  From reading the export corvettes use a steering wheel lock, and the US versions do not.
Hi @radi I have the same problem...Were you able to solve it?
Adelin exc11 Thamer Mo tan tan ve_nico Ahmed Ali BLKATSG tobiasp blocked Mikluha_Maklay Galaxie hassan77h crakavelli Arbe_gtc pupu14 Carlos Navarrete Last_Captain
