2009 GMC Acadia Seq programming
So I've been having great success programming various modules on my bench table with gm DPS.  I've run into a unique problem.  I can program any 2009 GM E69 ecms (2009 Acadia, outlook, Traverse, Enclave) part number 12623325.  What i gather is that i need the tcm to be able to program the ECM.  I was wondering is there a workaround or if someone had the calibration files for this module.
Solved by Last_Captain
  • Replies 6
  • Views 884
  • Last_Captain
    Last_Captain
    I hope this will help you, 100% tested file.2009 acadia ecm E69.zip
    U still need original PIN to deactivate old immo and then learn with new PIN. What is donor and target VIN?
  • kenjohn1204
    kenjohn1204
    It worked like a charm.  Thank you so much.
Is because SPS flash ECM then TCM in same time for some US models. Strange for me, but last week I see this for first time. If any of components isn’t present, doesn’t release calibrations
Bro I have Malibu 2013 with e78 I need reprogram used ecm I changed vin number but can't pin code Chang for immobilizer
You have files from it
VIN: KL1GM5DU5DB01868
I will send to you Saturday morning
George Chavez DrJerry AutoStreetDiag SCAMMER Slein karolputowski Beezer
