2017 Chevrolet Volt Power Inverter module
I need to change Vin and Pin? Help please
  • Replies 9
  • Views 1.1k
hi I can help you complete it
need dps software
You have the file for the PIN code?
You can provide the VIN
I have a PIN change .zip for this module I made from a utility file, but it doesn't seem to work on the bench just like other modules I've tried to change the PIN on the bench.  I'm not sure what other modules are needed.
Hi Cutter,do you resolve your problem if yes because my client have same issue after TCM module replacement and immo lock now,please send me infos,thanks.
TCM module has to be “Removed” from old vehicle VIN, Programmed to target car and Configured. Will be easy SPS job
Hi Lyubomir,the module is replace with use one from other car the problem is immo lock programming one time (Global A) need to change pin code in module before adapt immo learned function with SPS2,i have DPS Software but i'm not very good for modify file in xml pin change before reflash so not sure if someone can make flash for resolve problem,thanks.
Clear the anti-theft password of the module to complete the replacement work
Dannyguy Cutter collider bekatsilosani Artak Movsisyan Mikluha_Maklay MV_auto GMcars
