2 hours ago, OP said:
Hi can anyone help me with calibration file for A11 IOB radio with reverse camera for this VIN W0VZT8EP3M1018906
Read the first post, please.
  • Replies 876
  • Views 70.3k
"if you have....." wich I don`t at this moment
Insignia 2021 IOB_GCI_Log.Txt
  • Popular Post
here my friend OP
W0VZT8EP3M1018906_A11.zip
23 minutes ago, hassan77h said:
Thank you
Hi,
Can someone help with BCM Prepare for Removal and Immo learn of Meriva B.
Sample VIN which shares same cals W0LSH9ED0A4312720
BR,
  • Popular Post
Hi anyone can help me with ecu - bcm - immo for 3GNAXSEV6KS632567
can someone help with bins and Setup and calibrations for ECM and TCM - KLAJA69ED9K132666
Thanks in advance!
Thanks in advance!
And BCM please...
Hi confi files need for vin plz WOLPF6ED6A8017835 thanks
There are about 20 config files available - you need to be a bit more specific on what you want.
@pupu14 its for the body control module thanks
Here are the files. You will need to build archive for DPS yourself.
K9 BCM - 10010384 [13335507.xml].zip
Bins and Claibrations for KLAJA69ED9K132666 - BCM most wanted, please 🍻
ECU and TCM will be also needed soon
For ECM & TCM need to know Transmission part number and TCM hardware number.
If you can provide necessary info, I will check for the files and post in 5-6 hours.
Hi, I need files to log out/remove the K9 BCM and K20 ECM modules from the vehicle for both VINs:
W0LPF6ECXA8046942
W0LPD8EU2E8073066
Astra J A14NET
Thank you, it's 24253476, but as I see 24253478 is identical in terms of bins. May be some configuration DIDs will be different.
And for BCM it will be -T83, just in case:
W0LPF6ECXA8046942
W0LPD8EU2E8073066
Astra J A14NET
Need to know K20 ECU part number, as there is some variations in files for different HW numbers.
Request files for modules (BCM, ECM, IPC, EBCM, SQDM)
VIN: ⁠1GNSKEEC1KR341920⁠
Vehicle Details:
Model: 2019 Chevrolet Tahoe
Engine: 5.3L V8 L83 (Flex Fuel)
Modules Needed:
BCM (Body Control Module)
ECM (Engine Control Module - E92A)
IPC (Instrument Panel Cluster)
EBCM (Electronic Brake Control Module)
SQDM (Theft Deterrent Gateway)
Additional Notes / Context:
Hello everyone,
A massive thank you to a kind gentleman who shared some calibration files with me. I am sharing what I received right here in case it helps others.
To be completely honest, I am an amateur and I don't even really know how to use these files properly yet. I managed to flash an incorrect file into my Tahoe, and now the vehicle has a strict no-crank, no-start condition, and most of the time the instrument cluster doesn't even come on.
One major clue: the instrument cluster suddenly comes back to life when I disconnect the SQDM (theft deterrent gateway) wires, but otherwise stays completely dead/inactive due to the network/communication conflict.
Could anyone please help provide step-by-step instructions on how to correctly flash and recover these modules using DPS? Any SQDM files or guidance to help dig out of this mess would go a long way.
Thanks in advance for your patience and help!
Vehicle Details:
Modules Needed:
Hello everyone,
Troy offers paid courses on building a calibration data archive; this is the first course you should take https://www.cameraloops.ru/courses/category/1-general-motors-vehicle-programming-courses/
You have already received help with obtaining calibrations—which is a great start—but now you need to do some learning on your own; if you hit a complete dead end, you can ask a question, and you might get some help. The site also offers paid remote programming services for any GM modules https://www.cameraloops.ru/services/
If you go around asking for help everywhere without actually learning the process itself, you will simply get banned from the site.
Vehicle Details:
Modules Needed:
Hello everyone,
But I’ve already provided those files to you in the private thread you started—practically all of them...
https://www.cameraloops.ru/forums/topic/6857-urgent-wtb-request-module-files-bcm-ecm-ipc-ebcm-2019-chevy-tahoe-53l-flex-fuel/#findComment-18907
We warned about this back then.
If you don't know how this works, don't try it on a running car—at least not until you've learned how it operates.
You could brick the units or end up with a no-start condition...
I always like to search for VINs on Google to see what turns up :)
https://plc.auction/auction/lot/chevrolet-tahoe-2019-1gnskeec1kr341920-01-66214381#gallery
@geku Here you go..
P.S. you will need to create a BuildRecord.bld file with RPO codes for your VIN for K20 ECU setup - I do not have access to GM Korea database...
K9 BCM bin.zip K9 BCM setup.zip K20 ECM bin.zip K20 ECM setup.zip K71 TCM bin.zip K71 TCM setup.zip
6 minutes ago, pupu14 said:
@geku Here you go..
Awesome, thank you man! It's second time you help me 🤝
@Arbe_gtc hi there I’m sorry if I
@pupu14 thanks brother
  4. Arbe_gtc
alatka asd bondarrenko Opelinsignia1985 blocked Mikluha_Maklay Arbe_gtc BLKATSG Alpha hassan77h E-Ing-X20XEV pupu14 regloops Truhnder geku dfyznu Jasper Daniil_Ast Enterlan Cleberson Santos Autobitas
