  • Replies 849
  • Views 68.9k
4 minutes ago, hassan77h said:
Thank you, my friend.
6 hours ago, hassan77h said:
yes my brother ı will check same error
Thanks for checking,
I have another possibility:
Same $CB 13483128,
but VIN: W0LPD9E38F1073466
and $CB 13435756
with VIN: W0LPC6EB5E1005181
and RPO WGC Option GPS
That should give me the calibrations I need (in combination).
Thanks,
Toby
Hello! Help me download calibrations for the K9 BCM. 1G4PS5SK0C4200471 and LSGGF53F3BH284131. Thank you.
SPS_1G4PS5SK0C4200471_repack.zip
Tried to get the other VIN files, but can't get them. "No vehicle authorisation"
@Adelin Thanks, friend, that's already great!
@Adelin 1G4PT5SV5D4149204,
1G4PT5SV1D4102221
Can I try this pair? bcm
1G4PT5SV1D4102221
SPS_1G4PT5SV5D4149204_repack.zipSPS_1G4PT5SV1D4102221_repack.zip
Hello my friends. Can I try digital radio receiver A12? ECU ID: 89?
1GYEE637490104985
Request files for K9 BCM. Two VINs, same BCM OS 13524921:
1) My car: 3GNAXMEU2KS577702 (Chevrolet Equinox 2019, 1.6 diesel LH7, US). tis2web set: OS 13524921; 84575423, 84527924, 84515171, 84481229, 84558601 (Automatic Exterior Lights), 84481326 (Manual Exterior Lights), 84407525, 84481363, 84481404, 84481428, 84481445, 39155180, 84424867, 13524498, 13524500, 13524499, 84424793, 84424792, 84481205.
2) Donor: 3G0AX7E81JS618815 (Holden Equinox 2018, 1.6 diesel, amber rear turn signals). tis2web set: OS 13524921; 84415449, 84415456, 84415463, 84415486, 84415532 (Headlamp), 84415567 (Fog Lamp), 84415577, 84415625, 84415665, 84415698, 84415707, 39155180, 13524497, 84424869, 13524500, 13524499, 13524495, 13524496, 84415710.
Goal: enable the separate rear turn signal outputs (circuits 1334/1335) on my US car by flashing the donor exterior lighting calibrations with DPS, VIN untouched. Most needed: 84415532 and 84415567 (or any export/GCC Equinox 2018-2020 exterior lighting calibrations with amber rear turn). Also my own set for backup. I can send GDS2 ident of my BCM if needed. Thank you!
Hi can anyone help me with ecu and immo calibration for this vin K4CJESB7KB837268
Hİ Friend
Invalid Vin: Make sure vin is 17 characters and Alpha Numeric
1 minute ago, hassan77h said:
Hİ Friend
there's probably a one at the beginning
I think this is the VIN number KL4CJESB7KB837268
Точно
hello
i need calibrations files for
Air Conditioning Remote Control Module
2G1FB3D37E9220784
thanks
here friend A61bk
If you can get the controller ID and some module txt files from this car using DPS, I would appreciate it.
2G1FB3D37E9220784_K33.zip
6 minutes ago, hassan77h said:
here friend A61bk
this
ECC Remote Heater and Air Condition Control Module
ECU-ID 99
thanks
Yes, brother, I have already sent the ECC calibration files. But if you could read the other modules for me and send the results as TXT files, I can also download and archive the calibration files for those modules. They may be useful for other friends in the future as well.
ok
sorry. this vin KL4CJESB7KB837268
need ecu ans immo calibration
KL4CJESB7KB837268
I think this VIN belongs to a Holden. Do you have the calibration information for this vehicle? If you can send it to me, I can check my database—maybe I already have the corresponding .bin calibration files.
Otherwise, I can't check it because Opel TIS2Web does not support Holden vehicles.
Requesting calibration files for K157 VPCM and A33 Media Disc Player for 1GYS4DKJ9GR422035. Thank you in advance!
3 hours ago, hassan77h said:
KL4CJESB7KB837268
From buick encore 2019
Hi can anyone help me with calibration file for A11 IOB radio with reverse camera for this VIN W0VZT8EP3M1018906
  5. hassan77h
OP pupu14 aaronprg Enterlan ABOMAZEN regloops mlggggg jorgecostacv JBL_1989 Flash blocked hassan77h exc11 geku CapriceV Mikluha_Maklay jwinters Arbe_gtc Zarate-Solution Opelinsignia1985
