2.0 update stays at zero %
first of all this is an amazing forum.  kudos to all of you
my mothers 2015 yukon.  she ordered the maps update, and it stays on zero %.
sounds like the emmc is bad.
something tells me this is basic knowledge that I cant find, but is there a way to fix this?  she took it to the dealer and they couldnt fix it.
she I try and reflow the solder around the emmc?  is it replacement needed?
thanks in advance
  • Replies 6
  • Views 605
  • Then you will need to program the used HMI with DPS, or SPS, and do the VIN learn.
Easiest would be to just pick up a used one from Ebay for about $100.  It is either the 23228496 (AVF) or the 23266008 (non-AVF) in that Yukon.  There is a 1/2 year split so you need the VIN to check the RPO code for "AVF".
The non-2.5 HMI modules are pretty affordable.  If you don't want to upgrade to the 2.5 version.
thanks!
I'll probably just swap it out.
would be nice to get the carplay etc, but just getting it working will be better.
2.5s seem to be $300 plus all the other stuff I'd need to do apparently
was really hoping to repair the current one as sounds like something fried the writeable memory
11 minutes ago, chamilun said:
unfortunately not seeing too many $100 options.  $250+
Ummm I'm not sur how you are searching on ebay, but I found them easily.
23228496
Link1
Link2 (older version of same module)
23266008
Link3 (older version of same module)
youre the man.  thanks!
anyone want to program this thing for me?  I've done extensive BMW programming but none on GM
acff
