no sound, no audio, no fm tuning, no turn signal buzzer help!!
Yes.
  • Replies 33
  • Views 1.4k
  • a easy way to check if have or not internal amp, remove the two screws and in back the plate you should see the amplifier or only the holder for the integrated amplifier. Or, if the plate are cold on
  • Did you remove the theft lock? Program the radio and hmi using sps.
  • the car have bose amplifier? or does it have a standard speaker system? i means, speakers connected to the radio (green connector). I see it is an IO6/HMI 2.X system. If it does not have an external a
That would mean it doesn't have an amp correct?
RPO codes from a 2016 Denali.  Bose is UQA.
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
4AA - 5SA - PREFERRED EQUIPMENT GROUP PREFERRED EQUIPMENT GROUP
6NU - 7NU -
8X2 - 9X2 -
A31 - POWER WINDOWS A45 -
A48 - POWER SLIDING REAR WINDOW A68 -
A91 - REMOTE LOCKING TAILGATE AKO - DEEP TINT REAR GLASS
AL0 - AN3 - FULL FEATURE FRT. BUCKET SEATS
AQQ - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
AXK - AY0 - SIDE-IMPACT AIRBAGS FOR DRIVER/RIGHT FRONT PASSENGER HEAD-CURTAIN AIRBAGS FOR ALL OUTBOARD SEATING POSITIONS FOR FRONT AND REAR OUTBOARD SEAT POSITIONS.
B1J - REAR WHEELHOUSE LINERS B30 - FLOOR CARPETING WITH FLOOR MATS
B58 - CARPETED FLOOR MATS B85 - BRIGHT BODYSIDE MOULDINGS
BTV - REMOTE VEHICLE START BVQ - 6" CHROMED ASSIST STEPS
BWN - REAR BUMPER CORNERSTEPS C49 - REAR WINDOW DEFOGGER
C5Z - GVWR: 3266 KG (7200 LB) CF5 - POWER SLIDING GLASS SUNROOF
CGN - SPRAY-ON BEDLINER CJ2 - AUTOMATIC CLIMATE CONTROL
CTD - CARGO TIE DOWNS, UPPER (4) D07 -
DD8 - AUTO-DIMMING ISRV MIRROR DH6 -
DL3 - POWER FOLDING OUTSIDE MIRRORS DNS -
DP9 - CHROME MIRROR CAPS E20 - CHROME DOOR HANDLES
E63 - PICKUP BOX FE9 -
FHO - G80 - AUTO. LOCKING REAR DIFFERENTIAL
GBA - ONYX BLACK GU5 - REAR AXLE - 3.23 RATIO
H2X - JET BLACK I16 -
IO6 - INTELLILINK(TM) W/NAVIGATION JD9 -
JF4 - POWER ADJUSTABLE PEDALS JHD -
JL1 - TRAILER BRAKE CONTROLLER K05 - ENGINE BLOCK HEATER
K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
K4C - WIRELESS CHARGING KB6 - HEATED & VENTILATED FRT SEATS
KC4 - KG4 -
KI4 - 110V AC POWER OUTLET KNP - TRANSMISSION FLUID COOLER
L86 - ECOTEC3 6.2L DI V8, VVT, AFM M5U - 8-SPEED AUTOMATIC TRANSMISSION
MBC - MSL -
N37 - TILT/TELESCOPING STRG COLUMN NKC -
NP5 - LEATHER WRAPPED STEERING WHEEL NQH - AUTOTRAC 2-SPEED TRANSFER CASE
NT7 - NZZ - UNDERBODY SHIELD- TRANSFER CASE
PPA - 'EZ' LIFT & LOWER TAILGATE R7K -
R7W - MANDATORY VK3 RC4 - SPARE TIRE
RC7 - P275/55R-20 ALL-TERRAIN TIRES RTL - 20" CHROMED ALUMINUM WHEELS
RUF - SAF - TIRE CARRIER LOCK
SLM - SLT -
T3U - LED FRONT FOG LAMPS T4L - LED HEADLAMPS
TG5 - SINGLE-SLOT CD PLAYER TL1 -
TQ5 - U19 -
U2K - SIRIUSXM SATELLITE RADIO(TM). INCL. FIRST 3 MONTHS SERVICE. U2L -
U73 - UD5 - FRONT & REAR PARK ASSIST
UE1 - ONSTAR TURN-BY-TURN NAVIGATION UEU -
UF2 - LED CARGO BOX LIGHTING UG1 - UNIVERSAL HOME REMOTE
UHS - UHX -
UJM - TIRE PRESSURE MONITOR UK3 - STEERING WHEEL AUDIO CONTROLS
UQA - BOSE(R) SPEAKER SYSTEM UTJ -
UVC - REAR VISION CAMERA UVD - HEATED STEERING WHEEL
V76 - FRONT RECOVERY HOOKS (2) V8E -
VB5 - VH9 -
VHM - VK3 - LICENSE PLATE BRACKET, FRONT
VQZ - POLISHED EXHAUST TIP (LPO-DEALER INSTALLED) VRK -
VT5 - VT7 -
VV4 - ONSTAR 4G LTE WI-FI HOTSPOT WMG - 2016 MODEL YEAR
XL7 - Y86 - ENHANCED DRIVER ALERT PACKAGE
Y91 - YE9 -
YM8 - LPO IDENTIFIER Z49 - CANADIAN BASE EQUIPMENT
Z82 - TRAILERING PACKAGE Z88 -
Z95 - MAGNETIC RIDE CONTROL(R) ZY1 -
 yes No external amplifier
If the radio module was taken from a vehicle that did not have the HMI 2.5 module, you need to update the radio module's firmware so it has the HMI 2.5 specs. The firmware update will fix those problems.
Here is the radio module firmware.
But if the receiver I'm trying to install is from a truck with an external amp and this truck does not have it then this won't work, correct?
this files are not valid for US radios, are different brand/maker
US: Denso Ten/ Fujitsu Ten
EU: Delphi / Aptiv silverbox
for IO5/6 systems
Correct, it wont works. You need a radio with integrated amplifier.
But, if you now have a radio with internal amp, use the same radio. should works.
In insignia A 2014, with HMI 2.0, if i replace the HMI 2.0 to 2.5, all works fine.  (upgrading the radio works the sound of Android Auto/Carplay)
I've changed to a non bose radio.  Apple carplay works but android auto gives me an error.  Which update do I need to do?
marcel_hack_guy acff exc11 jjagel zamich85 Redsupra OpelGuy Buzz Eatable
