no sound, no audio, no fm tuning, no turn signal buzzer help!!
good morning, need help i change the radio,hmi,and display, and the cluster check all my fuses and relays still nothing, please help
  • Replies 33
  • Views 1.5k
  • a easy way to check if have or not internal amp, remove the two screws and in back the plate you should see the amplifier or only the holder for the integrated amplifier. Or, if the plate are cold on
  • Did you remove the theft lock? Program the radio and hmi using sps.
  • the car have bose amplifier? or does it have a standard speaker system? i means, speakers connected to the radio (green connector). I see it is an IO6/HMI 2.X system. If it does not have an external a
Also, what's the year, make model of the vehicle?  But overall, sounds like the radio module isn't calibrated or dead.
2015 sierra 3500 base dually
troy yes everything is on and working
Here is a video
the car have bose amplifier? or does it have a standard speaker system? i means, speakers connected to the radio (green connector). I see it is an IO6/HMI 2.X system. If it does not have an external amplifier (connected via MOST BUS), you need a radio that has an integrated amplifier and that has calibrations for an integrated amplifier.
There are some units not have internal AMP and only works with the bose amplifier
99% sure the radio doesn't have the correct calibrations.  It affects the amp as Arbe_gtc said and there are different calibrations for the controls.  You'll need radio calibrations from a base unit (I'm assuming that doesn't have Bose being a base truck).
ok ill do sps base cal and try that and no i dont have bose
a easy way to check if have or not internal amp, remove the two screws and in back the plate you should see the amplifier or only the holder for the integrated amplifier. Or, if the plate are cold on operation mode not have internal amp.
hmi from cadillac? unit vin to check amplifier? cadillac hmi dont have internal audio amplifier....
IMG_4518.jpeg.2333fb3a6ec9709a4094c33fc6e70e5d.jpegI need a new calibration anyone?
  • 7 months later...
How did you get this to work?  I have a 2014 silverado 1500 with no audio after the hmi, radio and usb upgrade.
Get a VIN from a 2016 truck that has about the same options as your truck.  Then program those calibrations into the radio module
I tried that with dps.  Didn't work.  Also, tried with sps but it won't let me.
Why wont it let you?
I finally got it to take a 16 vin.  But still no audio.
Could the radio be wrong?  This truck has IO5 and the radio I'm installing has IO6.
IO5 its the same as IO6
IO5 no integrated nav
IO6 integrated nav
ok, makes sense.  I've tried programming to a few different 16 silverado vins with no luck on both the radio and hmi module.
the radio 84278527, its for external amp. Your vehiche have bose sound?
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
2LZ - PREFERRED EQUIPMENT GROUP 4DP -
6F1 - 7FZ -
8X2 - 9X2 -
A31 - POWER WINDOWS A45 -
A48 - POWER SLIDING REAR WINDOW A60 - TAILGATE LOCK
A68 - AKO - DEEP TINT REAR GLASS
AL0 - AN3 - FULL FEATURE FRT. BUCKET SEATS
AQQ - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
AXK - AY0 -
B1J - REAR WHEELHOUSE LINERS B30 - FLOOR CARPETING WITH FLOOR MATS
B32 - FRONT FLOOR MATS B33 - REAR FLOOR MATS
B85 - BODY SIDE MOULDINGS BTV - REMOTE VEHICLE START
BWN - REAR BUMPER CORNERSTEPS C49 - REAR WINDOW DEFOGGER
C5Z - GVWR: 3266 KG (7200 LB) CJ2 - AUTOMATIC CLIMATE CONTROL
CTD - CARGO TIE DOWNS, UPPER (4) D07 -
DD8 - AUTO-DIMMING ISRV MIRROR DH6 -
DL3 - POWER OUTSIDE MIRRORS DP9 - CHROME MIRROR CAPS
E20 - CHROME DOOR HANDLES E63 - PICKUP BOX
FE9 - FHS - E85 CAPABLE FUEL SYSTEM
G80 - AUTO. LOCKING REAR DIFFERENTIAL GBA - BLACK
GU6 - REAR AXLE - 3.42 RATIO H0K - COCOA DUNE
I14 - IO5 - MYLINK(TM), 8" COLOUR TOUCH
JD9 - JHD -
JL1 - TRAILER BRAKE CONTROLLER K05 - ENGINE BLOCK HEATER
K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
KA1 - HEATED FRONT SEATS KC4 -
KG4 - KI4 - 110V AC POWER OUTLET
KNP - TRANSMISSION FLUID COOLER L83 - ECOTEC3 5.3L DI V8, VVT, AFM
MBC - MSL -
MYC - 6-SPEED AUTOMATIC TRANSMISSION N37 - TILT/TELESCOPING STRG COLUMN
NP5 - LEATHER WRAPPED STEERING WHEEL NQH - AUTOTRAC 2-SPEED TRANSFER CASE (4HI AND 4LO)
NT7 - NZZ - UNDERBODY SHIELD- TRANSFER CASE
PPA - 'EZ' LIFT & LOWER TAILGATE R7K -
R7W - MANDATORY VK3 RBX - P265/65R-18 ALL-TERRAIN TIRES
RC4 - SPARE TIRE RD1 - 18" BRIGHT MACH. ALUMINUM WHLS
ROO - BARS VOMS BAILMENT RUF -
SAF - TIRE CARRIER LOCK SLM -
SLT - T3U - FRONT FOG LAMPS
TG5 - SINGLE-SLOT CD PLAYER U19 -
U2M - SIRIUSXM SATELLITE RADIO(TM). INCL. FIRST 3 MONTHS SERVICE. U73 -
UDD - UE1 - ONSTAR TURN-BY-TURN NAVIGATION
UF2 - LED CARGO BOX LIGHTING UG1 - UNIVERSAL HOME REMOTE
UJM - TIRE PRESSURE MONITOR UK3 - STEERING WHEEL AUDIO CONTROLS
UQ3 - UTJ -
UVC - REAR VISION CAMERA V22 -
V46 - V76 - FRONT RECOVERY HOOKS (2)
V8E - VJH - RR CHROME BUMPER W/CORNERSTEPS
VK3 - FRONT LICENSE PLATE KIT VRK -
VT7 - VZE -
WEA - X88 -
XL7 - YE9 -
Z49 - CANADIAN BASE EQUIPMENT Z71 - OFF-ROAD SUSPENSION PACKAGE
Z82 - TRAILERING PACKAGE ZY1 -
Is UQ3 bose?
UQ3 i think its a radio whitout external amp. In the green plug, you have wires?
marcel_hack_guy acff exc11 jjagel zamich85 Redsupra OpelGuy Buzz Eatable
