service theft deterent system 2021 silverado 1500 4x4 smart keys
Need help with
Incorrect Environment Identifier Received From Electronic Brake Control Module
Incorrect Environment Identifier Received From Inflatable Restraint Sensing and Diagnostic Module
 Truck wont start
  • Replies 8
  • Views 658
  • Did you replace the EBCM and SDM with used part?  if yes, you will need to change the VIN and PIN in all those used modules and then remove and reprogram the vehicle's keys. More info can be foun
  • Which modules did you replace?
  • Reprogram the keys using the option in the that article will erase those DTC.
Change SDM PIN CODE
More info can be found in the weblink below.
2 minutes ago, Adrian Carrillo said:
i did not use any used modules
As Troy is asking, did you replace any though?  You must have to have tripped IMMO?
BCM, On Star, keyless module, hvac remote module, instrument cluster, steering lock module,
On 2/28/2024 at 11:40 PM, Adrian Carrillo said:
Need help with
 Truck wont start
IF CAR NOT START WITH ONLY THAT CODES,, YOU CAN START IT JUST REMOVE SDM AND BRAKE SYSTEM CONTROL MODULE FUSES,, IF STILL NO START SORT OTHER ISSUE,, DATA COMMUNICATION,,,,
exc11 collider Fazlullo Ubaydullayev GMcars DrJerry
