Chevrolet Malibu 2017
hi all can someone help me in this issue i have Chevrolet malibu 2017 and this car power steering control module is dead and now i replaced it with used 1 from the same model malibu 2017 and its giving me few errors and steering wheel turning hard below is the dtc information and when i trying to program it with sps2 its giving me error with my car vin and when i tried with scrapyard car vin from where i take the power steering its program normally so what can i do ? my car vin is KL1ZA5CAXHB713629  and used steering module vin is    1G1ZB5ST3HF157867
Solved by GM-Enthusiast
  • Views 1.2k
  • Hi, when recycling a used EPS you need to 1. Change the VIN is the EPS to match the vehicle’s VIN, 2. Program the EPS via SPS using the vehicle’s VIN, 3. Recalibrate the EPS using the SPS EPS setup an
  • Mustafa Shakir
    Mustafa Shakir
    Bro go to module 43 power steering And do setup and flow instructions if the error say event .... Something like that You can't do anything
  • Mustafa Shakir
    Mustafa Shakir
    Yes because hardware different
Hi, when recycling a used EPS you need to 1. Change the VIN is the EPS to match the vehicle’s VIN, 2. Program the EPS via SPS using the vehicle’s VIN, 3. Recalibrate the EPS using the SPS EPS setup and configuration function.
thanks for reply ..its giving error when config and setup
84187572  GEAR, ELEC DUAL PINION RACK & PINION STRG (CODE BXP) (ACDelco #84187572) ZB,ZC,ZD69 2017-2017 01   9A 0214A,, BOTH VIN YOU HAVE USE SAME EPS PART NUMBER,, THE MODULE WAS LOCKED,, ONLY U CAN DO IS VIN/CHANGE PIN,, THEN YOU CAN DO REPROGRAMMING AGAIN,,
hi thanks for reply.. how i can change VIN?
Go to Search ,, Type EPS Malibu,, links will appear  ,, for exact file send message to troy..
i ll check it to make sure
alialsayyed chicking Mikluha_Maklay Ty Rat
