Chevrolet Onix ECU. Reprogrammaing or tuning. Car and lock sign deactivation.
Dear friends, I have some questions on Chevrolet Onix (uzbekistan version, 1.2 amto) ECU reprogramming and car&lock sign on dashboard deactivation tips.
1. We recently installed methane gas on the car. It has passed about 12,000 km after it. Then suddenly the car won't start with car&lock sign on dashboard. Some mechanics are saying that it needs a new ECU. "ECU is gone". Can methane installation cause the loss of ECU program? Can chevrolet Onix ECU be reprogammed? Are all the chevrolet onix ECU's compatible with each other, though they have different engines (Mexico, China, Uzbekistan, Brazil)
2. Does it really require a new ECU or is the car's ECU can be programmed or restarted again?
Because this model is new in our country, the people are very skeptic about Onix. Especially, there are a lot of car traders in the secondary marked who accumulated Cobalt and gentra and running "antimarketing" of Onix. Saying to people that Onix is not good, ECU can be gone easily. I was wondering if the ECU is really damaged by fuel type. I attached the viedo, please help guys. Thank you so much.
  • Replies 16
  • Views 2.3k
    First of all you need diagnostic on vehicle to see what is show. Then need to check id to see if read ecu
    If no connection to ecu mean no communication, mean car doesn’t start and will not start until replacement ecu is supplied and programmed. You cannot turn off immo when ecu is not present/working
  • Asssalomu aleykum oka miyani ob keb korn qarab koramiz ozm ustaman
Thank you bro for your reply. The owner says mechanics could not connect to the ECU. They cannot switch off the immobilizer light.
In general, is there any available chip tuning for Chevrolet Onix 1.2L atmo engines?
Va Aleykum Assalom. Aka qaerdansiz? Biz Qoraqolpoqdanda... aka aniq uyg'ota olasmi? Chunki salondagilarga egasiga miyaga teginmang umuman, garantiya bo'yicha yangi miya obkeb beramiz 900 usd zamnga degan. Agar miya ochilgan bo'sa zamen bo'miydi, va yangi miya 10,000 usd bo'larmush 🤣. Egasiga qancha aytsamam riskovat qigisi yo'q. Qimmat bozori 200-300 ga bemalol toopsa bo'ladiyu Xitoyda
Aka nomerizni bering, qo'ng'roqlashib gaplashaylik. Sizga miyani o'zini yechib jo'natsak bo'ladimi?
Just to point, if not been used English in posts I will not put effort to translate and help. Please I understood is easy to use your language, but main language in forum is English. So if someone want help use English.
Ok, sorry bro.
On 14.11.2023 at 19:04, Timur Abdukarimov said:
Он же номеризни беринг, qo’ng’roqlashib гаплашайлик. Сизга мияни озини йечиб джонацак боладими?
Ha harakat qilbkorsa boladi 935886776 kotorolmasam sms qoldrin
Здравствуйте,у меня такая же проблема с ЭБУ Е64 ,пропадает вин код, с помощью md2 и ,sps. Не программируется (
English?
Lost VIN? After programming or? Is it visible via GDS? Via SPS
hello, the E64 ECU has a connection, but there is no option to rewrite the VIN code and immo, maybe someone has an in-circuit connection point or an MPS7383D5 can try to restore, I don't know what yet
On 04.01.2024 at 18:09, smr said:
здравствуйте, ЭБУ е64 есть подключение, но нет возможности переписать VIN код и иммо, может у кого-то есть внутрисхемная точка подключения или MPS7383D5 можно попробовать восстановить, пока не знаю что
935886776
I'll call you today, there are options
GMcars chita_it EUROTEAM2 Rafet hamelion Adelin Guilherme Formento srsfer
