Buick Regal 2015
Hello. Updated HMI from 2.0 to 2.5. sn 84089007) Now the question is where to find calibrations?
VIN 2G4GN5EX0F9298045
Solved by Arbe_gtc
  • Replies 16
  • Views 2.5k
U have to use donor VIN, as your is 2015 and is not intended to have HMI 2.5 and there is no calibrations for it. Or u can state what is your extras (camera, touchpad, etc.) and may there is package made by @Troy where can use it.
I understand that there are no calibrations for 2015. Could you download calibrations for a car with 2G4GM5EX5H9155534 ?
they are individual paid files. As well, your part number is not listen under other VIN, best solution is to use HMI donor VIN.
new hmi need online program, used hmi need only vin change.
HMI_2G4GM5EX5H9155534.7z
try this
Will have satnav but no GPS reception. Always can buy AliExpress GPS antenna and plug in hmi
the VINs you shared, don have Integrated navigation and the hmi 9007 dont have the blue plug for GPS antenna.
The calibrations defines what enables or not. you cant brick the HMI changin the calibrations. is the teory...
Have you unzipped the files and packaged them in order according to the TXT?
44 minutes ago, vladimius said:
incorrect, 02 to 11
the order is OK but the ID wrong check the Blob ID in the txt file
24 minutes ago, Arbe_gtc said:
incorrect, 02 to 11
Thank you!!! Everything worked!!!
MarcinFromSaturn
