RPO codes lookup
There was an option at PSA ServiceBox to check for Opel/Vauxhall recall campaign infos by entering VIN. As a side effect, it also provided full RPO equipment code list for the vehicle.
It seems that link for this service was removed (or moved to some other place) from the homepage.
Does anyone know where one can lookup RPO codes by VIN now, similarly to previously described service?
Solved by Arbe_gtc
  • Replies 19
  • Views 4.3k
Not available anymore in free service I think
Enter VIN on EPC or on SPS2,, RPO will dispayed.
we speak for European access system, not ACDelco
I look them in TIS2WEB
I DONT USE ACDELCO,, I USE TECHLINE GLOBAL
Techline Global is ACDelco TDS
ACDELCO IS FOR US/CANADA, SERVICEBOX FOR EUROPE,, GLOBAL FOR WORLWIDE GM DEALER,
19 hours ago, Arbe_gtc said:
Great, thank you so much!
  • 4 months later...
On 22.08.2023 at 01:24, Arbe_gtc said:
используйте это, все еще работает @pupu14
https://public.servicebox-parts.com/recallOV/
How do I register on the service?
Register as independent operator, it's free..
Also, probably, choose any other European county other than Russia when create an account. Or use VPN.
  • 5 months later...
Have this service worked for anyone recently?
I'm getting "Invalid VIN passed, please provide valid VIN number" on any VIN I try to check...
Is it only for my account, or it have stopped working?
Same problem, not working
It's working again.
  • 5 months later...
is there any way to get RPOs from VIN (Opel Corsa F)?
Servicebox? Give me VIN to check.
You won't get any RPOs for Corsa F, as this is a PSA vehicle. But you can get equipment info per VIN via ServiceBox.
Enter VIN, press Search, then go to Vehicle->Characteristics
M Ch Gekko kitsaras Robi_X mechanix Enterlan Danielb Camelot Kastis DrJerry BullMech Keep learning Autobitas hassan77h jesus teran empowered Adelin boorawchick Yovanni Sanchez High
