Need EBCM Calibration File
Hello guys,
I am doing a 16 Silverado EBCM, I am needing a calibration file for.
I think there is a server error on GM, I have tried calling techline with no success.
I can read the module with DPS and GDS2, it communicates, shows PN info with blank VIN. Tried a 2nd new module same issue, tried it on the bench, same issue.
I get a E4399 unable to obtain controller info error. I have tried using another PC, a genuine MDI2, mongoose, and clone MDI1 all have same fault.
I have troubleshot the truck checked the highspeed can bus, and serial wakeup has 12v ignition. Grounds are good. Can resistance is correct.
I feel like its on their server. I want to test it by flashing a cal with DPS, but cannot get to the download part as it errors out.
Would someone be willing to help? Can provide the VIN and pay for time.
  • Views 1.2k
1 hour ago, jake9713 said:
Hello guys,
Drop me PM 🙂 can give a try
all files sent via pm
Exactly what I needed, this helps me out a ton. Thank you 🙌
Let me know when test them.
