Lookin for bin file of bcm,
  • Replies 15
  • Views 2.4k
6 hours ago, Morooo said:
Car model corvette 2017 convertible stingray
Post your VIN
2 minutes ago, Morooo said:
1G1YD3D76H5117508
I just paid for gm emulator. If get software and activation today will download for you if these are available in PSA SPS, if not will check friend to download them from ACDelco
sent u files over PM. Include everything - programming part, setup part and car pin code
If u use vvdi should be complete file, not separate calibrations.
That is tricky part as require someone to have same bcm part number and to be programmed to this VIN, then to read eeprom and flash like read ECU for remap
Then you need to edit vin and pin and be sure car have same extras as your. Will be cheaper to buy mdi or mongoose to reprogram your
Thanks for your respond, if you get me the file for MCU D70F3558 of the corvette  BCM bin format, BCM part number 13515543, i can pay for it mate.
also there is other control modules need to be programmed
Sorry, but I cannot help. First need to buy same module, then need to buy equipment to read flash. I never do this as I directly program them with SPS. For you will be cheap to buy MDI clone and do it by SPS or DPS
11 hours ago, Morooo said:
I bought a subscription for one car, after i write my vin and connect the car i get this error
Use the control panel to delete TLC and all general motors applications that are connected to TLC, then re-install TLC. That should fix that issue.
Ryan W hassan77h
