Zafira C CNG
Hi. I have Zafira C 2014 Gas with CNG. I want to disable CNG. I disabled it in ECU. The main issue is that Fuel Level Indicator. I have tried changing IC configuration, but indicator is either ON all the time or blinking (depending on what i changed in configuration). Fuel is 50% so it shouldn't indicate low level. Can someone take a look what should I change? Or do I need to do configuration in BCM as well? Sending original IC config.
13476165
  • Views 1.4k
I already did P_CNG_LPG_PRESENT 0
P_FUEL_LEVEL_LOW_SECOND_ENABLE 0
P_FUEL_MODE_UNAVAILABLE_ENABLE 0
Any other ideas? Cant reply on PM
How about set P_CNG_FUEL_LEVEL_LOW_ENABLE (DID $03 byte 14 bit 6) to 0x0 and P_VEHICLE_PROPULSION_TYPE(DID $A5 byte 15 bit 0~2) to 0x00 (0x00-gas, 0x01-LPG, 0x02-CNG, 0x03-BAS electric, 0x04 - ext. range electric)?
P_VEHICLE_PROPULSION_TYPE set to 0x00 too.
I dont have P_CNG_FUEL_LEVEL_LOW_ENABLE parameter. My DID0003 is 9 byte long.
E-Ing-X20XEV Lyubomir Krastanov Astrafan
