DPS archive build for module configuration
Hope someone to willing to share. I have calibrations for configuration for BCM and IPC, but cannot find file where is stated which files and what sequence to create archive. So if @Troy or someone else willing to share how to identify this file or where stay until files been download will be very grateful.
Solved by Troy
  • Views 2.4k
A "caveman" approach - is to just check with TIS info. You will have your calibration files, and the extra one would be the utility file.
Sequence (or index) is also mentioned on TIS for a specific module - you should follow that.
There is a more automated way, for sure - surely this information is written inside utility file in a coded way. But seeing that DPS archive creator tool goes around here for a hefty price - I doubt that people will share this "secret" with you willingly, when there is a commercial gain.
I know how to create regular archives for reprogramming. That is different matter.
I don't completely understand the question mate but if it helps you, I've noticed byte 0003 of a calibration is equal to the Mod Id where it should be placed in the archive... hopefully that's at least half the answer for you..🙂
This tool can be used to automatically create DPS configuration files also known as Type4 files.
It can also be used to create GM global-A and global-B DPS archive files. Great tool
@Troy did will create archive for configuration options - like brake pedal learn, ipc configuration, tcm relearn.
Yes. Type4 files
13 hours ago, Troy said:
Yes. Type4 files
Then need to safe $50 and will buy it.
Looks like we've all learnt something...
kobrak16 bondarrenko Shurik Sharik Ahmed Ali charliebrown
