OnStar flash files
As OnStar stop working in EU/UK, I start one retrofit to make it with external sim and use as hot spot in car. Problem is where need US calibration to unlock functions. Anyone to help me if is possible?
  • Replies 22
  • Views 2.9k
  • Onstar.zip wifi_hotspot.zip
  • Mindaugas Cernius
    Mindaugas Cernius
    42646933 N/A New utility file to change the default value of the starter replacement proactive alert to customers.
  • Mindaugas Cernius
    Mindaugas Cernius
    It will be together
Are you looking for radio calibration?
no, I need OnStar - Telematic communication control module. may be in US have different name. Is device connect car to your MyBuick app and allow you remote control on some car features and give you option to call SOS or Buick assistance.
K73?
K73 Telematics Communication Interface Control Module?
1 minute ago, Mindaugas Cernius said:
K73?
ye, that what I need as in EU/UK is disabled with OTA, so need to flash manually and try to enable external SIM and use as hotspot.
42505400 N/A New utility file for start of production.
Selected Options:
VIN: xxxxxxxxxxxxxxx
Controller: K73 Telematics Communication Interface Control Module
Function: Programming & Service Activation
Programming Type: Normal
OnStar Version: Generation 10
Tomorrow grab to sps.
3 minutes ago, Mindaugas Cernius said:
Part Number CVN Description
84280879 N/A WiFi Enabling Function
Selected Options:
VIN: xxxxxxxxxxxxxx
Function: WiFi Enable Programming
Vehicle Options: Only for vehicles with RPO VV4 (WiFi)
It will be together
17 hours ago, Mindaugas Cernius said:
16008204 42646933
16007795
5 minutes ago, Mindaugas Cernius said:
Don't forget that usa bin-unzip
If there dont work you can write me i can enable it with different DID'S
May will need some help as I cannot flash these files. I have my original file if that will help.
Will try to flash them tomorrow.
onstar.zip that is my file, but is locked.I have wifi option but no option for lte
Okay so i have to write you the DIDs by hand.
@WSOpel I try to flash both files, but both fail.
which bus have you select ?
@WSOpel try 1 and 6/14, will try tonight and copy log files
Edited by Lyubomir Krastanov
@WSOpel so flash last night both files, but not change to Global A, left as Standard. Nothing change, still not show LTE coverage. Like SIM is not enabled. I have WiFi hotspot option and is active and have option to connect OnStar to my home WiFi. Looking how to enable external SIM. I got modification inside in module.
P.S. Images is from other car, but OnStar module is same. So no idea what need to done more. If you want I can share link to forum where is posted.Internet without OnStar with any 4G LTE SIM card 2.pdf
Okay we have to write Data to the Onstar Module. I have reactivate it in my Astra J 2018
  • 7 months later...
Hello
how to flash a telematics module on a 2023 Cadillac for add a eSIM for add internet onboard? On my country we have onstar service but don’t install on cars purchased outside to dealership
thank u
On 1/3/2024 at 2:21 AM, Leo E said:
Hello
thank u
You have to solder an Normal sim into it
catoboss bajad Bruno Anacleto BRANDON BURDEAUX exc11 RioCuartoScanner ajmiles vext__ Ahmy Layne Bumgarner Modx Mexico hussam alwan Thibs
