How to install GDS2 deliverable
  1. Select to show hidden files and folders in Windows.
  2. Put the deliverable in the location below and remove the current deliverable. C:, ProgramData, GDS 2, PersistentData, Downloads, DataBackups
  3. Start GDS2, and go to Manage Diagnostics Packages, and click on "Browse", in the open window find the deliverable at the same location you put it in above, click on it and then click open. GDS 2 will restart, Close out of GDS 2.
  4. Go back to this location, C:, ProgramData, GDS 2, PersistentData, Downloads
  5. Go to folder "CurrentRelease" copy the file example "deliverable_Saab v2017.01.0" place it into the folder "Deliverables" and delete the file that is in there so there aren't two different ones.
  6. Restart GDS 2, and it should be up and working to diagnose.
View full gm info
  • Replies 22
  • Views 7.5k
GO to file explorer option and click on "show hidden files"
normally programData folder is hidden
then go
C:\ProgramData\GDS 2\PersistentData\Downloads
  • 7 months later...
What does having the GDS deliverables do for me ?
It's a database of diagnostic actions, service procedures, what live data is available for each module, etc.
Without it GDS2 is useless - you won't be able to launch a diag session.
  • 4 months later...
Hi i have a corvette 2019 Grand Sport  and all installations is ok gds2+deliverable 2024 i put my key at on after choosing my year and car,  but i cant continue  the button continue still grey? is there a lockup in that model or what? thank you
Yeah, you don't have a connection with your car. Either you're choosing wrong VCI from the list, or it is not seen by GDS2 at all.
You don't have to choose year/model - GDS2 should read VIN and decodes it automatically.
ok thank you pupu14 for the info am gone to check.
p
I think that the GDS2 don't see my obd2 because when i started the gds2 it not make me choose what obd2 to use
Top left - press Select device button. What device you use?
I think its GDS2 activation isuue, please post picture to avoid confusion
It would tell you in red letters - "NO VALID LEASE FOUND", if it was a license activation issue..
If I remember correct, he would not be able to open "Diagnostics" tab without a valid lease too.
But posting a screenshot of GDS2 main screen would help to answer some questions, for sure..
when followed the steps from Troy, I still get to the point, where it needs to be installed. The app says it needs to restart... but after opening, there is still the status "Requires DGS2 install" although I already clicked it to install several times. I also copied the XML from "CurrentRelease" into folder "Deliverables".
Does anybody have any idea how to proceed?
U try to install packages not compapitable with your GDS2 release.
OK thanks. I rolled back to those originals and those work for now.
  • 6 months later...
where is the deliverable, is it a download?
C:ProgramDataGDS2PersistentDataDownloadsDataBackups
Easy solve for that you just need to have all the "RuntimeBackups" on the computer as well.
show scrrenshot of gds2 window? whatversion appear on lower left of screen,,, or try lower version of deliverables
Not sure why you are replying to me I am not having a problem!
If the OP has version 22.7.01500 installed and no other runtimebackups because he has never had the program installed before then a lot of older deliverable files will not load and will say "GDS2 Install Required".
The correct method if you want to run older versions of the deliverables is to have all the runtimebackups in the correct folder and if anyone does not know what I am talking about then I would suggest a good file browser and a little time investigating will net you a whole lot of understanding on how GDS2 actually works.
If anyone wants or need all the older runtimebacks let me know and will pack them up and upload them but the archive is quite large and really running older deliverables is a waste of time because when they release a new deliverable they keep all the older cars in it so you really only need the latest version of the deliverables. However some people like to explore all the older files but to do this means you need the older deliverables.
Sorry, i hit the wrong quote button.
autorepair robson stroker amretp drdolitle spd_dps JackMack Sergey Alexandrovich kourtly dentley tejiera Opelinsignia1985 ateyourveight Wlw2 mechanix cronkllr hootydavis EDGAR HC Kpeezy Nevin Joplin greaseman
