Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noise, PCV valve, Camshaft seal noise fix.
Recently my Insignia developed a squealing noise coming from the engine bay. The noise was coming from the camshaft seal and PCV valve located in the engine rocker cover. Due to the faulty PCV valve, the car was building up a lot of vacuum in the engine, sucking air through the camshaft seal. From reading on the web, this is a known GM fault that will happen over time in the 1.6 SIDI  A16XHT engine. In the USA, GM had a service bulletin regarding this issue on the Buick Cascada, which uses the same 1.6 SIDI engine as some Astra and Insignia here in Europe. In the USA, GM replaced the rocker cover free of charge. However, folks in Europe have to pay for the replacement.
In the video below, I demonstrate the issue and the replacement process
Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.Vauxhall, Opel Insignia, Astra 1.6 SIDI A16XHT squealing noice, PCV valve, Camshaft seal noise fix.
GM bulletin
  • Views 7k
  • Last_Captain
    Last_Captain
    hi, Bro its good enough knowledge for those who got such vehicles,Good luck.
  • Theres no feeling better than successfully doing a job like this.  Getting the gasket on again with no leaks.  Not accidentally dropping a coin in the engine :).  Nice job Troy, thanks for posting it.
I accidentally dropped one bolt in the engine bay never to be seen again 😀. The car is more responsive after the rocker cover change and one less bolt.
Nice
This still happening in B16SHT and D16SHT (200HP)
On 1/10/2023 at 8:56 PM, Arbe_gtc said:
Nice
Add TSB 18-E-3450
18-E-3450 ENG.pdf
blocked notovi
