  • Open Club
  • 151 members
  • Free
Enable LKA and/or ACC for Openpilot Gen2 16-18
2016-2018 only
Each year has specific calibration files.
*To convert 2016 to ACC since it never came with ACC you need to buy a new engine control module that's compatible with 2017 model year otherwise only LKA is possible.
For LKA only
All Gen2 Volts regardless of trim have LKA commands built-in the power steering module firmware just connect openpilot and do a fingerprint.
For LT ACC You need to flash
1. Engine control module
2. ABS control module
3. Body control module
For Premier ACC You need to flash
4. Front Camera
You will receive errors every time the car powers up unless you have ACC radar module installed and wired correctly.  LT models need radar and front camera installed.
Using DPS you can look up current calibrations in Dev. Programming Tool window, under Get Controller Info, enter ECUID then click Read Info. After reading under Software Module Identifier you need to match up the first ID number in the calibration table below. If they match you can update calibrations to use ACC. If they don't match STOP! Please consult with the creator of this guide.
2018 latest LKA and ACC calibrations
EBCM ECUID:28
ID Selected# Description
1 84304190 Operating system
2 84304196 Electronic brake
3 84304186 Electronic Brake Diagnostic Calibration
4 84304193 Function Enable Calibration
5 84304187 Driver mode brake calibration
6 84304183 Tire Pressure Calibration
7 84304182 Caliper Assist Calibration
Engine ECUID:11
1 12688925 New software to ensure proper operation of generic scan tools. Replaces 12687695 (CVN 0000D504).
2 12687805 New calibration for start of production
3 12687802 New calibration for start of production
4 12687809 New calibration for start of production
5 12687796 New calibration for start of production
6 12687791 New calibration for start of production
7 12650377 Slave Operating System
8 12667265 Engine
EPS ECUID:31
1 42690956 New Operating System to address DTC C056D.3B.
2 84219753 Calibration
3 84219754 System
BCM ECUID:40
1 13515935 Operating system
2 84096598 Accessory
3 84096600 Chassis Control
4 84096602 Charging/Energy Storage
5 84096604 I/P Occupant Display
6 84096608 Automatic Exterior Lights
7 84096613 Manual Exterior Lights
8 84096614 Interior Lights
9 84096617 Powertrain Control
10 84096621 Theft deterrent alarm
11 84096624 Locking
12 84096626 Wiper Control
13 13338869 Aux Alarm Sensing Control
14 23340493 Left Front Window Control
15 13505711 Right Front Window Control
16 13505709 Back Left Window Control
17 13505710 Back Right Window Control
18 13505707 Sunshade Control
19 13505708 Sunroof Control
20 84096627 HVAC Control
2017 latest LKA and ACC calibrations
EBCM ECUID:28
1 23394159 Operating system
2 84131366 New calibration for improved hydroplane counter measure.
3 23394158 Electronic brake
4 23461977 Electronic brake
5 23394136 Electronic brake
6 23394154 Electronic brake
7 23394155 Electronic brake
Engine ECUID:11
1 12683203 New Main Operating System Software with diagnostic enhancements to DTC P2457.
2 12693807 New calibration with diagnostic enhancements for DTCs P059F and P2097.
3 12683316 New calibration with diagnostic enhancements to DTC P2457.
4 12683317 New calibration with diagnostic enhancements to DTC P2457.
5 12693801 New calibration with diagnostic enhancements for DTCs P059F and P2097.
6 12693796 New calibration with diagnostic enhancements for DTCs P059F and P2097.
8 12667265 Engine
EPS ECUID:31
1 42692392 New Operating System to address DTC C056D.3B.
2 84076332 Calibration
3 84081630 System
BCM ECUID:40
2 84176879 Updated Calibration
3 84176881 Updated Calibration
4 84176883 Updated Calibration
5 84176885 Updated Calibration
6 84176889 Updated Calibration
7 84176894 Updated Calibration
8 84176895 Updated Calibration
9 84176898 Updated Calibration
10 84176902 Updated Calibration
11 84176905 Updated Calibration
12 84176907 Updated Calibration
20 84176908 Updated Calibration
2016 latest LKA calibrations
EPS ECUID:31
3 84219754 System
  • Replies 20
  • Views 4.1k
  • Did you do that and does it work? Than what is the role of the ASCM?
  • Jamesimpson
    Jamesimpson
    @VoltGuruthanks for this!  Can you explain what would be needed just to get LKA on a 2016 Volt LT?  I see you wrote that all it needs is Comma and a “fingerprint.”  What’s a “fingerprint” and how woul
  • Jamesimpson
    Jamesimpson
    So I found instructions online about how to fingerprint the car. Seems easy enough. Is that really all that would be needed to get LKA on a 2016 LT?  No hardware changes required?  Just a Comma 2 or 3
If you want to add openpilot ACC you can without that ASCM module. Openpilot will take care of the needed signals but you will need the radar installed and the programming changed for it to work. If you want OEM acc you will need that module but that's beyond the scope of this thread.
Yes I have flashed several Volts that didn't come with ACC and it works for openpilot now. You need radar installed.
I have a 2017 Volt LT and I followed the flash instructions by creating a Premier ACC cache file ("GM DPS Archive File From SPS Cache Files"}. I ordered the cache files with utility file as described above for the BCM, ECM, PSCM, EBCM. Everything said it was successful in DPS, but I am getting "x184 NOT SEEN" from OpenPilot.   From what I read it means that Openpilot cannot communicate with the Power Steering. Could the issue be with the firmware for the Body Control Module or Power Steering Module? Maybe does it mean the physical connections on the steering wheel are wrong? I did not touch the steering column so it is factory. Any help would be appreciated or I can pay for your time to resolve this issue. Thanks
Out of curiosity, if I try to run openPilot on the ELR and I retrofit the ACC sensor, would it work? Or is my steering rack not supported? The ELR seems to have a similar electrical architecture to the Gen2 volt
The ELR does not have Lane keep assist so it will not work. It's more of Gen1 Volt than Gen2 Volt.
Do you need to swap out the grille to install the radar module? Is their a bracket that the radar module is connected to that also needs to be ordered?
Yes you would remove the grille. The bracket is already installed for all trim Volts.
You could buy the radar grille but its pretty expensive. I just removed the chrome grille and will probably 3d print something for it.
Below is the link for the general instructions. I would use DPS to flash your firmware instead of SPS2 method.
GITHUB.COM
openpilot is an open source driver assistance system. openpilot performs the functions of Automated Lane Centering and Adaptive Cruise Control for over 200...
Okay, I am ordering parts to try this. I saw the list for LT does not include camera and only mention of camera on github was the Service Camera message that is resolved when Comma loads. With comma installed, is the front camera not necessary for LT? Also, wondering why Camera is needed for premier?
The camera is not needed for the LT. The is the cheapest radar connector when you order parts
WWW.EBAY.COM
Find many great new & used options and get the best deals for Cruise Control Radar Module CONNECTOR 2016 2017 2018 2019 2020 Cadillac CT6 at the best online prices at eBay...
Make sure you use the DPS method found on this website to flash your firmware correctly.
Also, the instructions are the opposite for USA cars. You will get a BIN file from SPS. You will need to use 7zip to extract them. The extracted files will not be BIN files. You then use these non-BIN files to make your archive file to flash.
I have a 2017 Premier with LKAS but no ACC.  I have purchased and installed the radar and programmed it using a OBD2 programmer and SPS.  I would love to get the OBD2 harness to work with Open Pilot, but always get a hardware malfunction error. When I look at the list of calibrations above, I noticed a few are different than what I have when I check my files.  Is there a repository where I can get the differing files?
The Comma log files should tell you what hardware is not communicating. It should say "Not Seen xxxxx"
You could also try a different fork like OPGM that doesn't use ACC to see if comma works without it. There are plenty of people on Discord that use Comma Pedal instead of ACC with good results too.
I did make all of the archive files if you want to try mine out. You should use DPS to install the new Volt Firmware.
I will take a look at the logs and see what isn't connecting, I hadn't thought about doing that..thanks for the suggestion. I have used the pedal interceptor in the past, not a big fan of it and I get the power reduced error about once a week with the pedal installed. I would like to try the archive files if you have them available.
Just following up to see if I can get the archive files.
@VoltGuruthanks for this!  Can you explain what would be needed just to get LKA on a 2016 Volt LT?  I see you wrote that all it needs is Comma and a “fingerprint.”  What’s a “fingerprint” and how would I go about doing that?  Thanks!!
So I found instructions online about how to fingerprint the car. Seems easy enough. Is that really all that would be needed to get LKA on a 2016 LT?  No hardware changes required?  Just a Comma 2 or 3 and the GM harness? Thanks!!
Yes that's all that's needed believe it or not.
Wow, that’s pretty cool, thanks!  Also, to get longitudinal control, I’d need to swap the engine control module and add a radar?  I assume that’s a very difficult process right? Thanks again!
Working on adding this to use Open Pilot. If I add this, is there any functionality that will not be supported by Open Pilot, or it will work the same as the premier does?
tobiasp Adelin schultp AMJar Troll Deryck blocked nev3r SHPSHP ratmen bekatsilosani Amplifier thxx lvulcan Pinballben F Mikluha_Maklay photoncat GMcars exc11 krzakx
