SDM AirBag PIN change
Without a pin code change in a used IPC, BCM, EBCM, and SDM you won’t be able to program those modules via GM online SPS service using the vehicle’s original PIN.
This DPS file can change the PIN CODE in most GM Global-A 5 bytes EBC ABS modules.
Important
  1. In order to change the PIN code in a used GM module, you will need to know the PIN code that’s already programmed/stored in that module. Without knowing that PIN code, you cannot change the PIN code in the modules using DPS
  2. You have to wait 12 minutes for the PIN code programming procedure to be completed by DPS.
Methods for knowing the PIN CODE stored in a used module.
Connect the used module to DPS, then use the "get Controller Info" option to know the VIN stored in the module.
You can then use this VIN to PIN service to know the PIN CODE stored in the used module.
VIN to PIN Service
Watch this video to see the process.
https://cameraloops.ru/uploads/videos/gm_pin_code_change.mp4
SDM AirBag PIN CODE Change DPS file, 2 bytes seed
SDM AirBag PIN CODE Change DPS file, 5 bytes seed
View full gm info
  • Views 1.1k
18 minutes ago, elmajestro said:
support sdm opel insignia b ?
Yes it does.
You figured it out!
Congrats.
9 hours ago, antek said:
You figured it out!
Congrats.
Yes, thanks. I finally cracked the DPS PIN change procedure.
Important
VIN to PIN Service
About The Author
Troy is a professional Artist, Photographer, Videographer, Musician and Creator with a love for arts, electronics, coding, hacking stuff, traveling, taking photos and creating internet content. He is also the founder of CameraLoops.com
Follow Me On Social Media
View full gm info
