IPC VIN Change
If you install a used IPC in a vehicle, more than likely the vehicle's mileage will not display on the IPC screen. You will need to do two things in order to get it working.
  1. You will need to change the VIN number in the used IPC to the VIM number of the vehicle.
  2. You will need to use GM SPS service to reprogram the vehicles keys (this is optional but if not done you will receive an IPC DTC).
Use my custom DPS files to quickly change the VIN number in the IPC module.
VIN change file for most 2-byte IPC
VIN change file for most GMC 2-byte IPC
VIN change file for most 5-byte IPC
IPC VIN change for Cadillac Escalade 2018
View full gm info
  • Replies 20
  • Views 2.5k
  • importjustin
    importjustin
    something that might help someone in the future is when reading cluster you need to read it on pin 1 not 6and14. adresss is 60. it tried for to long on pin 6and14
  • Need to clarify whether 2022 GMC YUKON is global A or B
  • GM-Enthusiast
    GM-Enthusiast
    Global B
Is that mean remote key?
Yes.
 I reprogramming keyless and keys but didn't work mileage
Usually in the car and not on the bench, if the IPC has the same vin as the BCM, the milage will show on the IPC. I don't know the issue you have, so I can't help.
10 minutes ago, ralphie said:
I bought a used cluster -- how can i get it to work in my 2019 (2019-2022) silverado?
If you have DPS and a pass-through device, you can do a read info from the IPC to see if it's a 2-byte or 5-byte seed/key.  Troy has an example in the BCM programming:
From there, you should be able to get the appropriate VIN change above in this article (2-byte or 5-byte) then do the VIN change through DPS.  Keep track of the old VIN as you should change the PIN too and you need the old VIN to find the current one to change it to match your vehicle.
2 hours ago, Dennis said:
I have a 2017 L5p is there any way to take out the IPC codes or make them inactive?
Which codes do you mean?
Probably mean when get cluster from donor and target car have missing RPO, that bring errors/dtc’s on display aka service messages
@Dennis yes is possible
Ahh yes, I found the response confusing lol
I had a can bus wire break and since then my DTC change oil soon I have changed it and tried to reset it but no luck it wont reset. service emissions ,tire monitor,, read owners manual.
Picture of diagnostic report?
Hello sorry so late I have been away from internet and normal 7-5 taking up my life. I believe my issue is with the broken wire I had on the DEF the system . worked great up until then and it shows that the def is low,the quality is low so I am going to try something in my wiring harness to see if I can make that go away?
  • 8 months later...
is there any pattern, which cars are 2-byte vs 5-byte? Maybe based on models or it is not model dependent and within e.g. Insignia or Astra models there might be difference?
41 minutes ago, Saeed Abuzaid said:
I have replaced used IPC for 2022 GMC YUKON XL
But Mileage is not showing
I performed SPS programming but failed
Is the DPS can do it ?
The VIN in the IPC must match the VIN in the BCM for the mileage to display. Also, if you drive the vehicle with an incorrect IPC VIN, the IPC will lock, and the mileage will not display even after the IPC is later updated with the correct vehicle VIN.
VIN and PIN change files.
Global B
ABOMAZEN MoeMan xsmart boostdp Robduramaxtruck Sajjad Turbo colibrig High Kpeezy mohamed montaser veetdoc raku_og jouhndggdh dt_precision Ahmed Naser hootydavis denis denis chicking Vrosado Carlos Navarrete
