DPS VIN & PIN Change Service For General Motors Vehicle Modules
This service is for folks who need to change the VIN and the PIN in a used secondhand General Motors electronic vehicle module, which is not already listed in the downloads section.
I strive to send you a private message with the DPS VIN or PIN change file between 30 minutes to a few hours, depending on your purchasing time and where I am located at the given time.
DPS VIN Change Service
You will receive a DPS archive file which can be used to change the VIN in any of these modules listed below.
Supported Global-A 2 or 5 byte seed modules.
IPC: Instrument panel cluster
BCM: Body control module
EBCM: Electronic brake control module
SDM: Sensing diagnostic module (Airbag)
EPS: Electronic power steering
ECC: Electronic Climate Control HVAC
  1. In order to create the DPS VIN change file, you will need to provide the vehicle model name, the year the vehicle was made and the module's SPS utility calibration file.
  2. Click here for the tutorial on how to acquire and identify the module's utility file.
  3. The modules must be Global-A, 2 or 5 byte seed key
You can purchase the DPS VIN change file service from the link below.
DPS PIN Change Service
You will receive a DPS archive file which can be used to change the PIN in any of these modules listed below.
  1. In order to create the DPS PIN change file, you will need to provide the vehicle model name, the year the vehicle was made and the module's SPS utility calibration file.
You can purchase the DPS PIN change file service from the link below.
  • Replies 21
  • Views 5.1k
So we can finally do Denali clusters? Maybe the Escalade ones too?
Yes you can change VIN and PIN in all GM clusters.
How I active and change codes in cluster by xml file?
On 12/4/2022 at 9:13 PM, dannygn said:
what about tcm modules?
Some TCM modules I can do.
On 12/14/2022 at 5:44 PM, Lenyn Sanchez said:
each file work for all vehicles or i have to get one file for each VIN number
Each file works for that specific GM model vehicle.
  • 5 weeks later...
31 minutes ago, CATLOS said:
com esse arquivo posso utilizar em outros modelos similares?
The files will work on a specific model vehicle.
I need to change vin and pin to a BCM with 8 connectors it is Global B seed 12byte can you help me2925B596-158A-4494-A88A-38783937B4FC.thumb.jpeg.4c07195b088381b9b414a5c8df964300.jpeg
Is this still able to be used on newer versions of Tech Connect/SPS2? I see a lot of tutorials, and screenshots you post have older SPS, just curious if it can still be used
Yes, it is the same process.
18 minutes ago, Emmerson Ganyau said:
Hi Troy
Can you get me a dps achive file to change vin in tcm for a 2015 chevrolet captiva 2.2 diesel
Hi, It's not possible to change the VIN in the TCM using DPS. That's something I'm still trying to figure out.
Thanks for the info.
So which dps achive file should I get for changing vin in Ebcm for the same car, Chevrolet captiva 2.2d 2015?
I would need to create the file. Tell me the VIN
Hi Troy.
I was thinking which vin number to give...
I have a car with all its original modules and not starting. Decided to buy all modules from an accident damaged car which was starting but couldn't manage to get the ebcm and tcm. So since you said the tcm vin can't be changed I'm thinking is it possible to change the ecm, cluster and bcm from the donor car to my vin?
I have the rcdlr and transponder as well, from the donor car. Is that going to work.
The car is a 2015 Chevrelot Captiva 2.2d
If it works then I will send my original vin
  • 11 months later...
Do we have to change the vin first then the pin or vice versa?
Hi Troy. I am building a custom truck with 2013 SS camaro interior, I have been able to program my BCM and ECM with SPS2. I need to change the VIN and PIN in my Gauge cluster. I would also like to turn off some of the errors. (Service electronic power steering, Service blind spot, Service air bag , Etc... Can you write a file for me to use in DPS to do this? (For payment of coarse) Thank you in advance. (I just want to get the immobilizer to learn my keys and get rid of the error codes on the gauge cluster. )
6 hours ago, cgtech said:
when using dps how do you do pin code (handshake) erase or replace when installing a used ecm in a gmc savana 2019 causing a p0513 code
different tool
Dallas Texas Dalton J xGhost syciu Dannyguy Vericu AutoOpel regloops lowcountry markramos cgtech GM-Enthusiast Galaxie Last_Captain xsmart Ahmadjon Rahimjanov Emmanuel Koomson Cleberson Santos Patricio Enterlan
