GM HMI 2.5 Activate Video In Motion, SAT-NAV In Motion, Track-Pad, Rear Camera And Climate Control using GM DPS
31 minutes ago, Troy said:
Does anyone has a working hmi 3 on a bench setup?
Can I access the Liunx by obd, and active the rvc?
  • Replies 42
  • Views 5.3k
  • Opel_driver
    Opel_driver
    I bought the file. VIM and trackpad in my 2014 Insignia now works with the upgraded HMI 2.5 using your file. 👏
  • I don't think that car with the LED option is using the HMI 2.5 module. I don't see any LED options in the HMI 2.5 module.
  • I wouldn’t now as we don’t have those cars in the UK.
I don’t have any knowledge about hmi3.
However it won’t me easy to activate rvc through Linux as you will need to know which code to edit and how to do it.
Just now, ChevyFan69 said:
Any luck with a US Chevy HMI 2.5?
Can you PM me your chevy HMI 2.5 calibration files? I can try to modify those files.
Been super busy with work. I'll have get my truck connected and get the calibration file for you.
yes
Is there a way to activate only one of the features? example vim without rvc or rvc without vim?
Bonus file: This package also includes a DPS archive with the rear camera turned off.
troy i have a us chevy hmi 2.5, do you want these calibration files?
Yes you could PM them to me thanks.
ANY LIGHT THAT BCM CONTROLLED,, JUST TAP RESISTOR 8R15W PARALLEL ON BULB CIRCUIT
On 19/08/2022 at 19:36, WWEILER said:
Sorry This is not the right place for My question.  Hyper Flash is when the turn signals blink fast do to installing led taillights (has to do with bulb outage).  And GM has a calibration update to fix it. Which is in the BCM.
JUST TAP 8R15W RESISTOR IN BULB CIRCUIT WHEN CHANGE TO LED,(PARALLEL CONNECTION
Will this file work in Cadillac/Chevy?
GOOD EVENING TROY, I'M NEW HERE
 AND I HAVE SOME QUESTIONS BEFORE I BUY.
ONE OF MY DOUBTS IS IF I CAN CHANGE
 THE VIN OF A HMI 2.5 BOSCH (8408 9148) PART 652029760
INSTALLED IN A GM S10 BRAZIL? THE ORIGINAL HMI IS NOT
 WORKING THE DISPLAY, WHEN I INSERT ANOTHER TURN ON THE
DISPLAY WORKS, BUT THEN THE ANTI THEFT MESSAGE APPEARS.
FOTO_webp.7d82bd1caf60fb5f5d7079b5d5b6853b
Hi, yes. You can use this file with GM DPS to change the VIN and remove the Theft Lock from the Radio and HMI 2.5.
I have another question to finish, since if I am an unlimited donor $150, I can make several daily downloads and etc… is this vin change file already included?
No, the VIN change file is a separate price/cost of $100.
Yes. Video in motion for all GM vehicles that use the HMI 2.5 module.
Erik chicking ViCo2 bekatsilosani KiT71 PixelTheKWolf exc11 choi remiga muraskinas stensin Adelin FASNASSRI ackalo
