Chevy Siverado Stop Start
  • Views 1.8k
  • I do on my car this way - cut the yellow wire (the wire that goes to the ECU) and connect it to the black-violet wire (wire that goes to BCM) through a 2.4Kom resistor. The engine ECU sees that the ho
  • GM-Enthusiast
    GM-Enthusiast
    15 SECONDS NEGATIVE OUTPUT TIMER CONNECT TO BCM CONNECTOR 1, PIN #12 BLUE WIRE, TIMER WAS TRIGGER BY START SIGNAL.
You will need an ECM flash. Unless you can find a proper binary for the bcm that only has that option disabled.
  • 6 months later...
On 5/1/2022 at 4:13 AM, Carfixr1977 said:
Any software to disable start stop function for 2019-2022 Chevy Silverado.
I do on my car this way - cut the yellow wire (the wire that goes to the ECU) and connect it to the black-violet wire (wire that goes to BCM) through a 2.4Kom resistor. The engine ECU sees that the hood is open and deactivates the start-stop, while the remote start works normally.
This schem from Ali and Amazon chinees cable 🤣
011_.jpg.ce676d644ca63dad01a6866232ffe00f.jpg11.jpg.1e72bbf49ae52f0ca92aa252c16fa1c9.jpg22.jpg.df6793d1cae8c3269e128266b80a8863.jpg33.jpg.01d60e5634db5e03d97edb5a3bb922d5.jpg
exc11 Enterlan chicking CarKeysForLess tungnv93pt
