Corsa E IPC Program error
Hello. I have a problem updating IPC with DPS. IPC is rebooting during the process, I am posting the log. Maybe some ideas ??licznik 150.log
  • Replies 11
  • Views 2.6k
On 1/2/2022 at 8:16 PM, zamich85 said:
Hello. I have a problem updating IPC with DPS. IPC is rebooting during the process, I am posting the log. Maybe some ideas ??  licznik 150.log  5.66 kB · 4 downloads
Are you programming IPC on bench as I only see IPC alone on the mapping matrix?
If so you may need to program the IPC in car connected with all the other modules.
when you say all other modules, does this mean the bcm ,hmi ecm and radio module
Yes program it via OBD port
Unfortunately, it did not work in the car. The same is happening.
Must be issue with the calibration files and the achieve file.
Once the archive file is build correctly there should be no issues programming it using DPS.
trying to learn this, utility code step 3 =f1 but no code was written. at the end utility code 3=ee , return to normal and code was written , is this normal
It will be a problem with your file, I reprogram corsa clusters on the bench with just the cluster powered up, no other modules connected.
Can I send you files for verification. It seems to me that it is ok.
What are you trying to achieve? Why do you need to load a cal file on the speedo
Problem solved. VXdiag is a problem on MDI2 works great.
Hello zamich85,
you sent me a message for Astra J 2012 IPC cal 5 TPMS enabled.
Unfortunately Troy changed the forums policy, that only +contributors are allowed to download files.
So I'll give it a try to contact you that way.
Cal 5 is for TPMS and AFL, I send you both files RPO UJN is TPMS - A8Z is AFL.
Greetings
Toby
05 - 13365560 UJN 05 - 13365558 A8Z UJN
regloops ABOMAZEN Mikluha_Maklay Mikkel Rasmussen stensin kaden exec Campean-Craciun Cristian SCAMMER Slein
