unlock e78 acdelco ecu from trax or cruze.
hi good morning.
i have some e78 ecu i try reprogram from sps but not possible because is used ecu.
i made the dsp file from sps cache but give error when try program (seek key) any one can help me to unlock this ecu.
and how can i change the ecu vin. because i have 2 cars working but with vin yyyyyyyyyyyyy and sps do no tel me reprogram again.
thank you
  • Views 4.3k
We haven't mastered changing vin in the ECU using DPS. The ECU is bit more tricky to figure out with DPS.
but is not possible unlock the ecu to reprgram again?
if u have any tool to connect e78 u can recovery it and write any flash and eeprom GEN1
Io terminal moze zrobić zrobic
Odblokowanie ecu nic nie da pozwoli na na dopisanie Immobilizera, ale nie pozwoli na wgranie oprogramowania Flash
Moge pomoc to zrobic
The VIN in the ECM can be changed during reflashing session.
ABOMAZEN ViCo2 Gote Adelin stensin JAM MOTOR Camelot tcautotech hassan77h wahab alnajdi Layne Bumgarner Lyubomir Krastanov Ahmed Ali kobrak16 BadBoiDJ uglyoldbastard stephanec mttweeks
