Issues with re-configuring E87 ECU
Hello all!
I have a bit of an issue here.
I was helping out to swap a damaged E87 ECU to a second-hand unit.
Hardware is 1:1 as the previously installed and corresponds to EPC part number for this VIN.
All went well, VIN and PIN got rewritten with car data, and reloaded correct calibrations.
Re-synced immo data for ECU..
Next step is Config & Setup - and here is the problem!
ECU refuses to proceed.
As I understand, this could be related to power-class data stored from the previous vehicle - DID27 Engine Performance Identifier.
It was previously installed in a car with A17DTC (81kW) engine, and now is installed into car with A17DTS (96kW).
Owner states that it does fill more sluggish than before - so, maybe, this value does change something in how ECU performs with the engine.
Does anyone know how to solve this, beside reading ECU with flashtools and editing the data?
Maybe my sequence was incorrect?
I do not want to waste time on "Prepare to remove" procedure and then re-syncing ECU again, if this won't fix this..
Also, what's weird, there is no seed/key data in XML File..
I've also tried to adjust it to info from utility file, but it gave the same error and couldn't proceed further.
Both files attached here:
util.binXMLFile.xml
  • Views 83
I have noticed just now, that there was "false" value for "Use security access"..
Does modifying XML to these values could resolve the issue?
like this:
<useSecurityAccess>True</useSecurityAccess>
<SecurityAlgoTableNo>01</SecurityAlgoTableNo>
<SecurityAlgoNo>17</SecurityAlgoNo>
like this:
Get both original and SH E87 VIN XML securityalgo and then see if it the same, if not, you can change them and to a ecu configuration in DPS
@Adelin good idea, XML p/n for donor VIN is different..
Security access from utility file is correct for this ECU, otherwise it would have not been programmed with correct cals.
I will try with original XML again, when owner comes back - because, although I have put correct algo inside it, I have not noticed that it was set as "false" too for security access at the time..
  3. regloops
  4. uglyoldbastard
crakavelli paul mike Camelot Adelin Arbe_gtc exc11 Ahmadjon Rahimjanov pupu14 tobiasp E-Ing-X20XEV
