[Help/Exchange] Onix Joy BCM Retrofit & Activ IPC Swap (Calibration Files)
Hello everyone,
I am working on a full retrofit project for my Onix Joy and am looking for technical support regarding the calibration files (.bin/.vbf) to avoid manual HxD editing and minimize bricking risks.
1. BCM (K9) – Objectives and Data
  • VIN: 9BGKL48U0KB211648
  • Part Number: 52119531
  • Features to enable:
    • Trunk release (Remote + Physical actuator).
    • Dimmer control (Rheostat via CAN).
    • Light miles
  • Need: I am looking for the original GM calibration files for these functions. I am aware these are not just isolated bits and bytes, and flashing via GM DPS would be the safest route.
2. IPC (Instrument Cluster) Swap
  • Upgrade: Joy → Activ.
  • Donor Cluster: VIN 9BGKC48V0KG244533.
  • Need: I need the configuration/sync data to ensure the mileage telltale and other Activ features communicate correctly with the BCM after calibration.
I am already familiar with the tools (J2534/DPS), but I prefer to follow the official GM programming workflow. If anyone has access to these files or can point me toward the correct repository, I would greatly appreciate it.
I will document the entire process and share the results with the community once the setup is fully functional.
GCI_Log BCM.Txt dump original active 2k.bin
  • Views 200
  • Cleberson Santos
    Cleberson Santos
    @Bruno Anacleto me chama no @crebs_santos
M Ch regloops Pavel PAMM Cleberson Santos junwan Bruno Anacleto JBL_1989 Camelot Opelinsignia1985 pupu14 blocked Mikluha_Maklay exc11 hassan77h Robi_X jingwei
