UQA Bose Retrofit Problem
Hey,
I have the following problem. I'm trying to retrofit the Bose amplifier on an I06.
Bose amplifier 39136620
Silver box 39132631
Connected to the MOSt ring, with GMLAN and MOST enabled. The MOST ring is also closed—at least the IPC, the HMI, and the radio are working. However, when the source is the HMI, I get a brief audio dropout every second. On my desk, I can access the Bose amplifier via VXDiag. In the car, though, I can’t. GMLAN is definitely connected.
Pro
Solved by marcel_hack_guy
  • Views 220
  • marcel_hack_guy
    marcel_hack_guy
    Problem solved. It Was an Hardware fault on the pcb of the bose amplifier. No Software problem
M Ch Adelin marcel_hack_guy aleks nik Pavel Camelot Robi_X jingwei Mikluha_Maklay BLKATSG pupu14 blocked hassan77h Opelinsignia1985 exc11 Galaxie crakavelli Cleberson Santos ViCo2 alatka asd
