SIERRA 2022 USED PSCM PROGRAMMING ISSUE
HI ALL I HAVE GMC SIERRA 2022 WITH VIN 3GTNU9EDXNG640469 ITS ELECTRONIC POWER STEERING CONTROL MODULE DAMAGED I PURCHASED PSCM FROM JUNK YARD WHICH IS SILVERADO 2024 WITH VIN 3GCND9ED8RG234244 AND I PROGRAMMED IT WITH TECHLINE VIN IS CHANGED NOW BUT WHEN I PERFORMING SERIAL DATA AUTHENTICATION CONFIGURATION ITS FAILED ALWAYS AND STEERING IS STILL HARD ANYONE FACE SAME PROBLEM BEFORE AND HAVE SOLUTION PLEASE SHARE THANK YOU
  • Views 244
Hi, check what dtc is set, is the VIN 3GTNU9EDXNG640469 is now in the PSCM ?
Yes vin in the PSCM now the problem is telematic control module no communication its dead thats why can't authenticate serial data is there any method to bypass telematic module?
Larzr regloops scanman Inam Ullah sbticket Firestars Dog RubenTX Emmanuel Koomson High Ahmy Leonardo Acosta paul mike xsmart BLKATSG J Brown mcOreos Galaxie TunnerXP Christos Tsirdanis Mikluha_Maklay
