Opel rainsense indicator
Hello everyone, has anyone tried activating the rain sensor indicator on the dashboard of an astra j or cruze? I soldered the necessary elements according to the scheme, and activated the P_RAINSENSE_INDICATOR_ENABLED parameter via dps and xmlfile. But the indicator is only flickering, I read it is a problem with the software. Is there anything else you need to turn on?
  • Views 241
I know to retrofit the sensor the BCM needs recalibration. But i not know what the rain sensor Indikator is
Okay cool. You never stop learning
there is no indicator on dash, except message pop on car start up, which should say "Rain sense wipers active" or similar.
E-Ing-X20XEV ABOMAZEN alatka asd LekTr Encrypted Owner mechanix Robi_X Laila Opelinsignia1985 JBL_1989 Enterlan Camelot tobiasp bondarrenko GMcars Galaxie blocked pupu14 marcel_hack_guy Lyubomir Krastanov
