gm global b anti-theft system vats
hello
i have gmc 2024 sierra
I have a used ECM.
Is it possible to disable vats option to start car the same global A?
thanks
  • Views 502
  • Richard Beauchamp
    Richard Beauchamp
    Im currently doing the same thing. were you able to figure this out? I can help in other ways involving this.
  • First check seed key, if all 00 00 00.. or FF FF FF.. - ECM soft bricked or modded
hi,
have you tried to reflash with TLC?
4 hours ago, blocked said:
hi,
yes in TLC
reflash in TLC changed OS calibration For the new VIN number
If VIN number changed - relearn immo
i try Immobilizer Relearn
gey msg
VTD Secure access locked
coz this ECM used and different pin number
also i try in
HPT disable vats
but not starting
in global A 2019 2020 2021 after HPT disable vats Vehicle starting
No, I haven't found a solution to this problem.
Could you please help me with it? Thank you.
you have to change stored PIN/Security code in ECM.
I know this, but is there a way to change it?
DPS ?
5 minutes ago, A61bk said:
DPS ?
unsure if is possible with offline DPS as you will need to calculate Seed key
I can calculate the seed , but how to get the pin change file ?
Do i need to create calibration file same as Global A
Hi, can you share more on "I can calculate the seed " , if it is Global B
  2. GM-Enthusiast
  5. wofy
    +wofy
rodimiro  romero pupu14 GM-Enthusiast Mikluha_Maklay Mohammed Aljack paul mike Jahaziel Ulivarria A61bk Truhnder Arbe_gtc Pasha Camelot Opelinsignia1985 blocked Lyubomir Krastanov BLUE LION SHARAWI crakavelli bekatsilosani Obada Alrifaee
